rappel353 Posted April 4, 2021 Share Posted April 4, 2021 Is it normal for Poly Sustain to drop out after a snapshot change? None of the Poly Sustain parameters are linked to Snapshots for changes. Anyone else see this? Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 4, 2021 Share Posted April 4, 2021 Yes, that can be normal. One of the most common uses of snapshots is to toggle FX blocks on/off as you switch snapshots. This is independent of any parameter changes being assigned to the Snapshot controller. If you want the block to be ON in all snapshots, one way to do it is to visit each snapshot individually, turn the block on manually, and Save the preset before visiting the next snapshot. Quote Link to comment Share on other sites More sharing options...
PierM Posted April 4, 2021 Share Posted April 4, 2021 If you want a block bypass to not be stored in any snapshot, select that block, press Action button, and set Snapshot Bypass Off. 1 2 Quote Link to comment Share on other sites More sharing options...
rappel353 Posted April 5, 2021 Author Share Posted April 5, 2021 Thank you all for your informative replies. PierM, Thank YOU for making me aware of that function. I had never seen it before and probably would not have understood what it did even if I had. I set Snapshot Bypass to Off for the Poly Sustain block and now it works the way I had hoped. Again, thanks to all who responded so quickly. Bob 1 Quote Link to comment Share on other sites More sharing options...
