Jacknass Posted April 18, 2021 Share Posted April 18, 2021 KakaoTalk_Video_2021-04-19-02-30-06.mp4 When I save a preset in hx edit or Hx Effects, all other presets change like this video...Plz Help me.... KakaoTalk_Video_2021-04-19-02-30-06.mp4 Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 18, 2021 Share Posted April 18, 2021 Are you running the latest version of HX Edit? If so, did you do a factory reset after updating to 3.10? Quote Link to comment Share on other sites More sharing options...
Jacknass Posted April 18, 2021 Author Share Posted April 18, 2021 56 minutes ago, phil_m said: Are you running the latest version of HX Edit? If so, did you do a factory reset after updating to 3.10? My Hx edit version is 3.10 How to reset factory?? and should i reset factory?? Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 18, 2021 Share Posted April 18, 2021 See release notes. Quote Link to comment Share on other sites More sharing options...
Jacknass Posted April 19, 2021 Author Share Posted April 19, 2021 13 hours ago, silverhead said: See release notes. this? There's nothing here related to me? Plz Help me everybody...... Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 19, 2021 Share Posted April 19, 2021 50 minutes ago, Jacknass said: There's nothing here related to me? Hi, Yes there is - the third bullet point, under the paragraph heading “Anything else I should know”. As you cannot find it there, the information is also available, if you click on the white question mark in the black dot in the lower right corner of this page. From the pop-up menu, scroll down to - Common Product FAQ > Hardware Reset Procedures. HX Effects: Turn unit off and then turn back on. Hold Footswitch 6 and Tap throughout the boot process, until you see that your factory presets are loading. If you run into any trouble with a failed update or your unit will not boot up, try powering on while holding the right arrow ">" This will put the unit into update mode and you can re-install the latest firmware from there. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
