keithlandry09 Posted June 25, 2021 Share Posted June 25, 2021 I bought a Variax 600 and a POD HD500 recently, with the Variax cable. Plugged it all in when I got it and the Variax didn’t work. Returned and bought a jtv. When I got it, the same thing, electronics wouldn’t work. Mags work fine though. My question is, if I take the battery out of the guitar and plug it into a POD HD500 via the Variax port, that should power the guitar without it having a battery, correct? So my problem most likely lies with the POD? Quote Link to comment Share on other sites More sharing options...
hurghanico Posted June 25, 2021 Share Posted June 25, 2021 8 hours ago, keithlandry09 said: if I take the battery out of the guitar and plug it into a POD HD500 via the Variax port, that should power the guitar without it having a battery, correct? Correct!.. no battery needed when using the VDI connection 8 hours ago, keithlandry09 said: So my problem most likely lies with the POD? probably.. but your issue could be due also to the Variax cable.. maybe it is faulty or you didn't insert it correctly all the way.. just for checking purposes (normally you should use a properly made Variax cable), if you have an ethernet cable around (ie exactly the same you would use to connect a computer directly to a router) and you know that is working fine, use it to connect the Variax to the POD.. it should work, if it doesn't it means that the VDI port of the POD (or of the Variax) is damaged.. sometimes it may happen that you accidentally insert a jack into the wrong hole like the VDI port and damage the delicate pins that are inside it _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
keithlandry09 Posted June 25, 2021 Author Share Posted June 25, 2021 Thank you for the response! The VDI cable is brand new, so it shouldn’t be the problem. I returned the hd500 and bought the 500x, should be here Monday. So hopefully that solves my problem. update- I think I’m an idiot. I don’t remember pushing the model knob in, so it may have been operator error lol. Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted June 25, 2021 Share Posted June 25, 2021 5 hours ago, keithlandry09 said: Thank you for the response! The VDI cable is brand new, so it shouldn’t be the problem. I returned the hd500 and bought the 500x, should be here Monday. So hopefully that solves my problem. update- I think I’m an idiot. I don’t remember pushing the model knob in, so it may have been operator error lol. Man, I think you forget to select the "Variax" Input on your Hd500 Page 3 on your Pod HD screen: Inputs 1 select Variax Inputs 2 select Variax if you use the dual channel Quote Link to comment Share on other sites More sharing options...
psarkissian Posted June 28, 2021 Share Posted June 28, 2021 What Punkyboy said. There is an edit page and select the inputs you want to use. Quote Link to comment Share on other sites More sharing options...
