Tkayyali Posted August 11, 2021 Share Posted August 11, 2021 i got a melon audio microphone and i am using audix t50k , i connected it to my line6 hx stomp , i can hear my guitar but the microphone not, i tried to connect the microphone direct to mic input and it worked but not with line6 hx stomp , is it because the mic is not compatible with it or is there any solution Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 11, 2021 Share Posted August 11, 2021 The mic probably need significantly more gain than a guitar to get the level high enough for you to hear it. 1 Quote Link to comment Share on other sites More sharing options...
Schmalle Posted August 11, 2021 Share Posted August 11, 2021 If the mic needs phantom power it's not compatible directly and via the impedance converter. Quote Link to comment Share on other sites More sharing options...
datacommando Posted August 11, 2021 Share Posted August 11, 2021 10 hours ago, Tkayyali said: i got a melon audio microphone and i am using audix t50k , i connected it to my line6 hx stomp , i can hear my guitar but the microphone not, i tried to connect the microphone direct to mic input and it worked but not with line6 hx stomp , is it because the mic is not compatible with it or is there any solution Hi, This video covers using the Audix T50k converter with a mic and XLR cable, although in this case it is a Peavey dynamic microphone (similar to SM58). I don't know anything about Melon Audio, other than they make a foam pop filter and a really cheap condenser microphone - their website give no indication of if it requires 48v phantom power. If it does then I guess you're out of luck. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
