danbottomburp Posted September 10, 2021 Share Posted September 10, 2021 So i have been messing around with a few amp sims and they just dont sound good at all with the Helix, i see many youtube videos of people playing with them and yes i know there could be post edit going on, mine sounds dreadful I will just stick with Amplitube 5 so we all know where we are, i have Guitar ----- then USB 3/4 ----------- then USB 3/4 ----------- XLR on the Helix In amplitube i have input L&R as 3/4 and Output L&R as 3/4 The guitar impedance in helix is Auto Global EQ is off I just cant seem to get Amplitube 5 sounding good, it sounds kinda muffled is the best way to describe it Can someone post some easy to follow settings for the Helix and the Amp Sim so i can try them and see if it makes a difference, if you could show screenshots that would be insanely helpful Thanks Dan Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted September 10, 2021 Share Posted September 10, 2021 Try recording some DI track (default: USB 7/8) and send that into Amplitube. See if things get any better. In case it's better, you may need to sort out some Helix settings, in case it's not, you may not like Amplitube. 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted September 11, 2021 Share Posted September 11, 2021 Mine sounds fine with your configuration. Don't know if it will help, but the attached file came from IK Support. Install it here: C:\Users\your user name\AppData\Roaming\IK Multimedia\AmpliTube 5. Then reboot and restart AT5. settings.properties Quote Link to comment Share on other sites More sharing options...
codamedia Posted September 11, 2021 Share Posted September 11, 2021 OK.... none of the Helix amp sims sound good AND Amplitude 5 doesn't sound good when the signal to the computer is coming from the Helix. Obviously, something is painfully wrong! ANY OF IT should sound decent, just a matter of adjusting to tastes. Some troubleshooting will be required to find to the problem. Check your guitar cables, check your guitar, try multiples of everything, try a new USB cable, check your monitors, etc... etc... etc... Quote Link to comment Share on other sites More sharing options...
danbottomburp Posted September 12, 2021 Author Share Posted September 12, 2021 On 9/11/2021 at 4:03 AM, rd2rk said: Mine sounds fine with your configuration. Don't know if it will help, but the attached file came from IK Support. Install it here: C:\Users\your user name\AppData\Roaming\IK Multimedia\AmpliTube 5. Then reboot and restart AT5. isn't that for a HX Stomp? Thanks for all the replies On 9/11/2021 at 4:03 AM, rd2rk said: settings.properties 680 B · 2 downloads Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted September 12, 2021 Share Posted September 12, 2021 So, does the Helix sound good to you on its own? Otherwise you might indeed have to check your cables and such. Quote Link to comment Share on other sites More sharing options...
danbottomburp Posted September 12, 2021 Author Share Posted September 12, 2021 Sounds superb on its own, absolutely amazing, just that Amp Sim sounds rubbish, really muffled, i have the benefit of having a Mac machine and on that it sounds better but not amazingly better, but i did try using Scuffham S Gear through both and it sound infinitely better when using my Mac machine, something is not right on the Helix, i will keep messing around and trying to get it sounding good, i appreciate all the help, many thanks indeed Quote Link to comment Share on other sites More sharing options...
rd2rk Posted September 13, 2021 Share Posted September 13, 2021 9 hours ago, danbottomburp said: isn't that for a HX Stomp? No, it' an AT5 configuration file that came from IK Support in response to various problems with AT5. The AI doesn't matter, I use it with HXS, Helix Floor and Scarlett 18i20. As I said, I don't know that it will help with your problem, which could be as simple as you don't like AT5. Quote Link to comment Share on other sites More sharing options...
danbottomburp Posted September 13, 2021 Author Share Posted September 13, 2021 The configuration file is from a HX Stomp and when used with my Helix Rack I get no sound at all, thanks anyway Quote Link to comment Share on other sites More sharing options...
rd2rk Posted September 13, 2021 Share Posted September 13, 2021 The file has nothing to do with the HXS. It's a configuration file with the driver variables written in from your choices on the Audio Settings page of AT5. When I use it with Helix it says "ASIO HELIX". When I use it with the Scarlett it says "Focusrite USB ASIO". When you open the Audio Settings page, it reflects whatever is in the file. Run AT5, go to the Audio Settings Page and enter the proper settings for your system. Then close AT5 and open the settings file from it's location in C:\Users\your user name\AppData\Roaming\IK Multimedia\AmpliTube 5. It should now reflect your entries on the Audio Settings page. I just repeated this process on both my office and studio systems, and it worked in both places. All I know is that, unless you just don't like the way AT5 sounds, the problem is elsewhere in your system. I'm using three different AIs, and putting it through 3 different playback systems (Sony bookshelf with HXS, Rokit6 Studio Monitors or PC212+ with Helix and Scarlett), and the output is NOT muffled at all. Maybe time to contact IK Support? Quote Link to comment Share on other sites More sharing options...
