xz0so Posted March 10, 2014 Share Posted March 10, 2014 I just got in my new dt25 head, I hook up to it via L6 link from my hd500. It sounds awesome but l`ve noticed I few issues and I was curious if anyone else has experienced this. When I switch from one patch to another there is an audible pop as the dt25 reconfigures its power section. I don't know if it's important to note this is in low volume mode, haven't tried full volume. Second issue I setup dual amps say a Vox ac 30 and a fender blackface on the same patch. One off and one on, both tied to the same foot switch that way I can a/b between. However sometimes when switching the knobs on the pod and the dt25 are not able to control the selected amp any longer.Thanks,Mike Quote Link to comment Share on other sites More sharing options...
drschultz Posted March 11, 2014 Share Posted March 11, 2014 The pop sound is normal when the amp is changing the power section. Yeah it can be a hassle but I don't know of any amps that reconfigure themselves that way. I don't use low power mode much. Since the the firmware update to the HD500 uses the master control it makes the tone much more usable at lower volumes. I have not done a dual amp patch so can't speak for the other issue. Quote Link to comment Share on other sites More sharing options...
Brazzy Posted March 11, 2014 Share Posted March 11, 2014 I'm pretty sure what your experiencing is normal behavior. I remember having the same issues so I just made my patches accordingly, be creative and go a different route. Quote Link to comment Share on other sites More sharing options...
radatats Posted March 12, 2014 Share Posted March 12, 2014 DT knobs will only sync with the amp in channel A. If you turn off the amp in channel A, the DT will switch to its internal channel B amp and whatever knob settings you have. Quote Link to comment Share on other sites More sharing options...
xz0so Posted March 12, 2014 Author Share Posted March 12, 2014 Yes I just discovered the usefulness of the master on the pod when hooked to the dt25 it really is sweet. Thanks for the input on the patches, I knew I could switch that way, just wanted to make sure that after spending 900 bucks I wasn't getting shorted. Thanks, Mike Quote Link to comment Share on other sites More sharing options...
