pipelineaudio1 Posted February 21, 2022 Share Posted February 21, 2022 If you only plug send one out, will it sum to mono? If not, what can I do to be sure send 1 has both channels' information Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 21, 2022 Share Posted February 21, 2022 The physical outputs on Helix are labeled to indicate this. Outputs labeled L/Mono indicate that the signal is summed to mono if only that output in the stereo pair is used. Outputs that are not labeled as such carry only their side of the stereo signal. The manual clearly states that the Return blocks are mono. I expect the Send blocks are similar but I’m not sure. It may depend on whether you use a TS (mono) a or TRS (stereo) cable. To be sure it’s summed to mono you could place a mono FX block (e.g. Simple EQ) immediately before the Send block. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 21, 2022 Share Posted February 21, 2022 11 minutes ago, silverhead said: I’m not sure about the behaviour of the Send and Return blocks in this respect. It may depend on whether you use a TS (mono) a or TRS (stereo) cable. It helps when asking questions if you specify what device you're asking about. If you use a MONO Send Block it's summed to MONO. Physical Sends are TS on the full fat Helix and HXFX. For Stereo you use a STEREO FX Loop Block and two Send/Return jacks. On the HXS/HXSXL a TRS Send carries Send L on Tip and Send R on Ring. A STEREO FX Loop Block splits the signal L/R-Tip/Ring. 2 Quote Link to comment Share on other sites More sharing options...
