HX Edit won't create a backup
Briand135
Hi guys, I'm trying to update my Helix floor to 3.15 and when I try to create a backup it goes through the process but instead of creating a backup I get a message that says "HX Edit was unable to backup some of the presets because the required licenses were not found.  The following product packs are available for purchase from Helix Marketplace.    *65022"         Any clues as to what this means and is there a work-around?  I bough this unit used a year ago and it had a lot of user presets already installed.  Yes, I've already updated HX Edit.
It sounds like this is some sort of licensing issue and I would contact Line6 directly to see if they can sort it out.
9 hours ago, Percy71 said:
Hi.
Same for me. HX Edit 3.15 wont create any back up. Nothing happens when while clicking on Create Backup. not when choosing Restore... or Extract... either.
Not sure if this is the same issue @Briand135 is having. Did you buy used or have software installed from the Marketplace that requires licensing?
In the event, for either of you, that this is an erroneous message caused by a technical issue I would probably do the following. You can skip to the last paragraph immediately for a possible resolution, but I would go through the checklist first.
  1. Did you do a factory reset per the update instructions after updating to 3.15? If you haven't done the factory reset and you have a decent prior backup already, then do one and attempt a restore.
  2. Ensure that your version of HX Edit and firmware are at 3.15. Open the 'Help' --> 'About HX Edit' screen in HX Edit and check the top and bottom version numbers for the editor and firmware. If they are both at 3.15 and you still can't get a proper backup or restore, move on to the next paragraph.
Try the following solution If you updated to HX Edit 3.15 directly through the automated update within HX Edit and still can't get a backup and restore. Instead, download HX Edit 3.15 directly from the Line 6 website and install it. Now try your backup/restore. If you want to be thorough, uninstall your Line 6 software first before doing the reinstall of HX Edit 3.15.
  • 2 years later...
I am having the same issue, my Helix Floor will not back up either through the update link or via the HX-Edit. I have nothing installed that shouldn't be but cannot update from 3.60. I have the latest 3.70 HX-Edit??
If I select File and Create a backup.. absolutely nothing happens
If I select Updates available and this opens Helix Floor Updates and tells me Helix firmware 3.71 is available ..... If I select update now, this takes to to a screen that tells me Step 1 Create backup, If I select OK I get  Backup dialog failed to load. Click to retry, from there nothing happens.
When seeking assistance from Forum users it's a really good idea to supply as much information as possible regarding the computer and operating system you are using. Also, the OP in this thread mentions certain Marketplace Products - you didn’t indicate if this is relevant in your situation? If not, did you try the possible solution provided by @HonestOpinion in the post above?
Try with more information, rather than a generic “me too”.
Hope this helps/makes sense.
Why would someone recommend doing a factory reset? we will loose all our sounds. If we could back up then, no problem however, the problem is that we cannot perform a backup, HX-Edit nor the update will allow me to perform one and I don't want to lose my sounds.
I have never had an issue updating the Helix before, why now? is there a bug in the update? I don't have any 3rd party downloads on my Helix
I run win 11 not that that should made any difference.
A Factory Reset is recommended to clear any possible glitches, or corrupted presets in your unit. This is best performed when you have already created a full backup of all your presets, setlists etc. You do make regular backups of your stuff don’t you? If you do then you should already have a recent “fail safe” copy on your PC.
If you do not have a recent backup you can still revert your HX Edit to the version you had been using previously. If the earlier version is still not able to make a backup, you should still be able to export a bundle, setlists and presets as you would do for normal saving of presets. The slightly more long winded way is to drag and drop all your presets into a folder, or folders, on your computer. Once you know your presets are “safe”, perform a Factory Reset on your device, and proceed with the update to v.3.71.
Because you are dealing with a computer and they can be notoriously temperamental. It’s not just “why now?” It can happen anytime.
Is there a bug in the update?
Nope! Lot’s of happy users out here in Helix-land.
  • 9 months later...
It is for sure a bug in HX Edit if you issue the menu command to create a backup and then nothing happens. All the explanations given have nothing to do with that bug. Every user friendly software has to inform the user if something does not work as expected. If possible the alert produced should then also give as much information as possible about the reasons that lead to the error. I am a programmer and I know that this is the rule to follow. While I appreciate that in above discussion efforts were made to help, Line6 programmers ought to recognise my point. Let me also add that error messages such as "An error has occurred" are not the kind of messages that are helpful. It is of course better than nothing at all (which is the case in my situation right now, HX Edit 2.9.2, HX Effects needing a firmware update). However, I hate these messages as the programmer needs to give more information to really help the user. As a programmer I know that where such an error messages is produced, HX Edit is at a particular point in the algorithm. The alert produced should then give information describing that point/condition in the algorithm as much as possible. E.g. the firmware does not match, then provide that information, e.g. what firmware version HX Edit expects at that point, and then say also what HX Edit needs at that point to proceed etc. That is good and user-friendly software. Just nothing simply means faulty software.
