HX FX: how to recall Snapshots quickly without pressing Banks simultaneously?
Stromer
I want to use Snapshots live in a gig, I have understood how to create them, but... Is there a quick way to recall them without pressing Bank up and Bank down simultaneously?
And obviously using only feet...
You can assign snapshots to switches in Stomp Mode using the HX Snapshot command in the Command Center. So depending on how you want to use snapshots and stomps, you can do a lot of different things. You can also have the function of those snapshot switches change per snapshot. It allows you to be pretty creative as to how you want to set things up.
In stomp mode, you could have your 4 snapshots in a preset on say, switches 1-3 and 4-6.
Then on say, switch 2, you could assign an HX Preset. That switch could then take you to your next preset, previous one or whatever preset you want it to take you to, and it does it a lot quicker.
The only risk you take, is accidentally pressing the preset button during a gig, etc.
You can setup the Preset Footswitch Mode (the "main" mode) so that the top row are presets and the bottom row are snapshots (or the other way around I think). It's in the Global settings area.
