Recommended OHM Rating for Headsets
bfoster71
On 8/30/2022 at 9:55 PM, bfoster71 said:
I have a Helix LT - bought it last year (2021). What is the recommended OHM rating if I purchase a headset to use with it? And is there any specific headset(s) that Line 6 has recommended that may work best?
Thank you!
This sort of issue as been discussed at length many, many times in here, but for a definitive answer, check this from the man himself:
Digital Igloo - Eric Klein, Chief Product Design Architect, Yamaha Guitar Group / Line 6 / Ampeg
“Helix's headphone amp is LOUD; it's designed to drive high-impedance studio headphones to stage volumes. Low impedance headphones distort way faster, fatigue your ears, and at a high enough volume, can damage your hearing. With Helix you could conceivably split the headphone output to two pairs of 200-300 Ω cans/IEMs and drive both over the sound of a drummer (and adjust respective levels via MIDI CC control of path output blocks). My band does this now.”
link to original post where he says he uses Sennheiser HD600 rated at 300Ω.
https://www.thegearpage.net/board/index.php?threads/line6-helix.1586637/page-1184#post-22007938
Hope this helps/makes sense.
  • 1 year later...
On 8/25/2024 at 12:14 PM, jaimeiniesta said:
Oh man now I'm confused. I use Beyerdynamic DT-770 Pro 80 Ohm but I'm not quite happy. So I read in this thread that I should go for 200 or 300 Ohms, and also the opposite, 32 Ohm... Any more opinions? Is the HX Stomp really different in this aspect?
Oh, you'll get opinions alright, lol... and no two will be the same.
I've used a bunch of different cans over the years, some with impedance well below the recommended range, and others well above. And I could have made my ears bleed with all of them if I wanted to... so frankly, these discussions have always baffled me. I suspect that those having issues with low volume either have a hardware problem with the headphone amp, or there's a leveling issue elsewhere in the signal chain.
  • Upvote 2
