Main Menu Fault ?
titchyblackcat
You are looking at snapshots probably. Or stomps. Blank because there are no names given to them.  Or no buttons assigned to stomps.
Familiarize yourself with what snapshots and stomp / “pedalboard” mode are. Also ways to set up your display: all snapshots, all stomps, upper/lower row snapshots/stomps. It’s in the manual, or watch some videos.
On 9/23/2022 at 8:45 AM, titchyblackcat said:
Any ideas Please ?
Not much to go on here, although when weird stuff starts to happen - perform a Factory Reset.
You haven’t said if you press the “Home” button does it change to “Signal Flow View”?
If you hit FS6 MODE does it switch to Preset, Stomp or both BANK UP & DOWN simultaneously to go to Snapshot view?
If it has screwed up - Factory Reset - power up the LT while holding down FS7 & 8.
Hope this helps/makes sense.
