boynigel Posted October 28, 2022 Share Posted October 28, 2022 Would love to be able to import my painstakingly crafted presets from my LT into Native. Easiest way? Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted October 28, 2022 Share Posted October 28, 2022 Drag them straight from HX Edit to Native. Make sure you have the same IRs loaded in either, in case you're using some. 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted October 28, 2022 Share Posted October 28, 2022 On 10/28/2022 at 6:04 PM, boynigel said: Easiest way? Drag and drop from HX Edit, just like Sascha said. Works the same the other way too. Bear in mind that you can set Native to Hardware Compatibility Mode allowing even the HX Effect unit to be matched, but any hardware Send/Return, FXLoops blocks and any of the Loopers will not work - it’s a software plugin. Oh, yeah - as usual this is fully documented in the Helix Native Pilot’s Guide v3.15 - Rev P. Page 14 onward. https://line6.com/data/6/0a020a4179ea61fd2e9472da7/application/pdf/Helix Native 3.15 Pilot's Guide - English .pdf Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
codamedia Posted October 29, 2022 Share Posted October 29, 2022 Drag and drop as suggested... or.... I keep my presets in a single "working" set list. I just export that setlist then import it into Native. As stated already... be mindful of the IR's, those need to be loaded separately. Quote Link to comment Share on other sites More sharing options...
