cdip72 Posted March 25, 2014 Share Posted March 25, 2014 Hi all, I upgraded my DT25 to new firmware but I don't know how to change preamp model e reverb model without POD. Is there an editor for DT amps ? For example, how can I set, on channel A-II, Hiway preamp and Hall reverb ? thanks Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted March 25, 2014 Share Posted March 25, 2014 http://line6.com/support/topic/124-user-created-dt-editors/ Quote Link to comment Share on other sites More sharing options...
GazzaBloom Posted March 25, 2014 Share Posted March 25, 2014 I asked the same question....look to the top of this discussion page....see pinned post with links to Midi editors that will send data messages to make the changes. You will also need thew Midi implementation guide from the L6 manuals page for the DT25. Gazza Quote Link to comment Share on other sites More sharing options...
cdip72 Posted March 25, 2014 Author Share Posted March 25, 2014 thanks to all Carmine Quote Link to comment Share on other sites More sharing options...
cdip72 Posted March 26, 2014 Author Share Posted March 26, 2014 However, as I understand it, the new firmware is useless when used with the POD HD, because all the preamp models are already in the POD. Is that right ? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted March 26, 2014 Share Posted March 26, 2014 Kind of... but still worthwhile as there are some fixes to the amp model defaults and some L6LINK enhancements. Quote Link to comment Share on other sites More sharing options...
stumblinman Posted March 26, 2014 Share Posted March 26, 2014 My favorite part of the new firmware is choosing the reverb I want and assigning it to the amp to free up the fx slot and DSP from the Pod. However, as I understand it, the new firmware is useless when used with the POD HD, because all the preamp models are already in the POD. Is that right ? 2 Quote Link to comment Share on other sites More sharing options...
cuuhl Posted March 26, 2014 Share Posted March 26, 2014 Is there any reason I would want to consider NOT doing the V 2.0 update? I don't use a Pod HD, and like to keep things fairly simple. Are the additional tone options that dramatically different/enhanced compared to the existing options? I already have a HOF reverb pedal, so I'm not that concerned about those enhancements. Thanks Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted March 26, 2014 Share Posted March 26, 2014 if you dont use a pd, then there's WAY more reason to do the update.... becomes a complete amp factory... you can customize all the topologies and other amp setting to anything the pod offers.... as well as make combinations of amps not possible on the pod. Quote Link to comment Share on other sites More sharing options...
cdip72 Posted March 26, 2014 Author Share Posted March 26, 2014 After I upgraded to 2.0, the first default sound (ch A/I) has a very low volume. Very strangely, volume increases when I set "low volume mode" to on. I hope it doesn't be a tubes problem. Now I'll try to downgrade firmware Quote Link to comment Share on other sites More sharing options...
cdip72 Posted March 26, 2014 Author Share Posted March 26, 2014 The firmware's downgrade solved the problem ..I don't undesrtand You do not have this problem on volume with 2.0 ? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted March 26, 2014 Share Posted March 26, 2014 I don't have the issue. could be bad defaults. had you loaded up one of the dt customizer programs and changed it around or reset the defaults? Quote Link to comment Share on other sites More sharing options...
cdip72 Posted March 26, 2014 Author Share Posted March 26, 2014 No, I didn't use customizer programs for edit defaults. It was the default sound of firmware. I'll try to flash 2.0 again Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted March 26, 2014 Share Posted March 26, 2014 I would try using the customizer. if you get the same result. Quote Link to comment Share on other sites More sharing options...
cdip72 Posted March 26, 2014 Author Share Posted March 26, 2014 I flashed 2.0 againIn attachment, the default amp with firmware 2.0. When I switch "low volume mode" to on, the volume increases Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted March 26, 2014 Share Posted March 26, 2014 that may be normal. i can't recall... i haven't had the stock models loaded for quite some time. but in low volume mode you are adding back the power amp modeling.... in regular mode, you might need to turn up the master or channel volume depending on the model. if you ignore the difference between low volume and regular mode, can you dial in an amp worthy volume? Quote Link to comment Share on other sites More sharing options...
cdip72 Posted March 26, 2014 Author Share Posted March 26, 2014 with master and amp's volume at max, volume is however low ... i can play in my home p.s. The problem is only for Blackface. If I choose Tweed, the volume is higher, perhaps because boost is set to on However, it's lower than firmware 1.0 Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted March 26, 2014 Share Posted March 26, 2014 I'm out of ideas, have you contacted L6 support? http://line6.com/company/contact/ might open a ticket or give them a call. Quote Link to comment Share on other sites More sharing options...
cdip72 Posted March 26, 2014 Author Share Posted March 26, 2014 I'll tray. thanks Quote Link to comment Share on other sites More sharing options...
stumblinman Posted March 27, 2014 Share Posted March 27, 2014 There was another thread about this a while ago. It was concluded that that's the way the models are. I am at work and don't have time to search, but it was a fairly recent thread in here. Quote Link to comment Share on other sites More sharing options...
cdip72 Posted March 29, 2014 Author Share Posted March 29, 2014 There was another thread about this a while ago. It was concluded that that's the way the models are. I am at work and don't have time to search, but it was a fairly recent thread in here. In fact, this is the answer of Line6 Support: "Hey Carmine, That's a Fender model on NFL 1....That's actually normal as a Twin or Deluxe has no gain control...just one volume...dime the channel volume and use the drive for volume when using NFL 1...tonestack completely changes between amp models I hope this help." Maybe, the only way is increase volume using drive. My favorite part of the new firmware is choosing the reverb I want and assigning it to the amp to free up the fx slot and DSP from the Pod. How do you do it ? You must connect POD in send/return of the DT25 and disable the preamp of POD ? In this case, the switch on POD is set to "amp" instead of "line" ? I hope my English is understandable .. Quote Link to comment Share on other sites More sharing options...
stumblinman Posted March 29, 2014 Share Posted March 29, 2014 In fact, this is the answer of Line6 Support: "Hey Carmine, That's a Fender model on NFL 1....That's actually normal as a Twin or Deluxe has no gain control...just one volume...dime the channel volume and use the drive for volume when using NFL 1...tonestack completely changes between amp models I hope this help." Maybe, the only way is increase volume using drive. How do you do it ? You must connect POD in send/return of the DT25 and disable the preamp of POD ? In this case, the switch on POD is set to "amp" instead of "line" ? I hope my English is understandable .. To use the amp reverb, just select the reverb model you want by using the DT edit program for channel A, then turn the reverb knob up on the amp until you get the amount you want. Quote Link to comment Share on other sites More sharing options...
cuuhl Posted April 1, 2014 Share Posted April 1, 2014 if you dont use a pd, then there's WAY more reason to do the update.... becomes a complete amp factory... you can customize all the topologies and other amp setting to anything the pod offers.... as well as make combinations of amps not possible on the pod. So then I would need to use a laptop to control/modify the settings? If yes, then how to the controls on the amp work? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted April 1, 2014 Share Posted April 1, 2014 once you make your choices they are sticky... then you just use it like a regular amp... So then I would need to use a laptop to control/modify the settings? If yes, then how to the controls on the amp work? Quote Link to comment Share on other sites More sharing options...
mariuszmm Posted August 13, 2020 Share Posted August 13, 2020 I really don't like blackface sound after upgrade to 2.0, does anyone have the 1.0 firmware file for DT25 HD ? - please :) Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 13, 2020 Share Posted August 13, 2020 8 minutes ago, mariuszmm said: I really don't like blackface sound after upgrade to 2.0, does anyone have the 1.0 firmware file for DT25 HD ? - please :) The modeling didn't really change at all with the update. It could be a setting that changed, I suppose. Quote Link to comment Share on other sites More sharing options...
mariuszmm Posted August 13, 2020 Share Posted August 13, 2020 The sound has changed drastically - and I do not mean the volume. I'd love to have my old blackface sound back again in my amp :( After update every amp model sounds much more digital :(((( Quote Link to comment Share on other sites More sharing options...
mariuszmm Posted August 13, 2020 Share Posted August 13, 2020 On 3/26/2014 at 7:42 PM, cdip72 said: The firmware's downgrade solved the problem ..I don't undesrtand You do not have this problem on volume with 2.0 ? Hi. Do you still have the 1.0 firmware file ? Quote Link to comment Share on other sites More sharing options...
mirzar123 Posted January 23, 2021 Share Posted January 23, 2021 Hello. I'm trying to find 1.0 firmware life for DT25. Please help. Regards MZ Quote Link to comment Share on other sites More sharing options...
