batflash Posted January 26, 2023 Share Posted January 26, 2023 Hey all, So this weekend my HX stomp's rotary encoder #2 (of 3) went bad. The switch mechanism either gave out or was crushed internally, not sure. However, it stopped receiving button presses on encoder 2 under the screen. Long story short, I spent hours looking up posts, parts, sites, and came across what seemed like a compatible match. I soldered in the part a few moments ago and it works like OEM! I hope this helps anyone looking for the part. With ALLL that said, I can't guarantee that his works for the Helix as it does the HX. I've taken apart both units a few times for maintenance, however I just can't recall what was in the Helix Floor. Likely the same part. Here's the info: Digi-Key Part Number: PEC11R-4015F-S0024-ND Manufacturer: Bourns Inc. Manufacturer Product Number: PEC11R-4015F-S0024 Description: ROTARY ENCODER MECHANICAL 24PPR Encoder Type: Mechanical Output Type: Quadrature (Incremental) Pulses Per Revolution: 24 Actuater Type: Flatted D 6mm Detent: No Built in Switch: Yes Mounting Type: Panel PCB Orientation: Vertical Termination: PC Pin DigiKey Link: https://www.digikey.com/en/products/detail/bourns-inc/PEC11R-4015F-S0024/4499668?utm_medium=email&utm_source=oce&utm_campaign=4251_OCE23RT&utm_content=productdetail_US&utm_cid=3294583&so=79660503&mkt_tok=MDI4LVNYSy01MDcAAAGJeZwhRZlHpMczuFUKJJnBAI1cw3UpEiZQU9lj1m6djk3uIrKIfkkv702-v2drrxYburU4cGCOMTLMqBRAgNp_JnbIz01ZS88mDLPy61Z9 1 3 4 Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted January 26, 2023 Share Posted January 26, 2023 Excellent, that might be valuable information one day! 1 1 Quote Link to comment Share on other sites More sharing options...
LucasGrijander Posted April 10, 2023 Share Posted April 10, 2023 Thank you very much... Do know if it is valid for the Edit/Action rotary pots? Quote Link to comment Share on other sites More sharing options...
MayPRS Posted April 11, 2023 Share Posted April 11, 2023 Many thanks!!! Quote Link to comment Share on other sites More sharing options...
rekrdskratcher Posted June 20, 2024 Share Posted June 20, 2024 It might be a stretch (and I know this is an old post), any idea if that part works for the other type of rotary encoder on the HX series (the one with a detent feel to it)? Obviously that changes the feel but if functionality is the same, that might help me with a jam I'm in with my out of warranty HX Effects's "Big Knob" no longer working consistently... Quote Link to comment Share on other sites More sharing options...
Schmalle Posted June 20, 2024 Share Posted June 20, 2024 On 6/20/2024 at 9:29 PM, rekrdskratcher said: It might be a stretch (and I know this is an old post), any idea if that part works for the other type of rotary encoder on the HX series (the one with a detent feel to it)? Obviously that changes the feel but if functionality is the same, that might help me with a jam I'm in with my out of warranty HX Effects's "Big Knob" no longer working consistently... I'd ask customer support about details of that encoder pot. Or contact a support center and let them repair it. Quote Link to comment Share on other sites More sharing options...
batflash Posted July 28, 2024 Author Share Posted July 28, 2024 Well, having all sorts of troubles with the Helix Floor encoders now. I'm going to take this behemoth apart and swap out the encoders for the stock I purchased when the HX Stomp encoder went bad. I'll report back soon! Quote Link to comment Share on other sites More sharing options...
craiganderton Posted July 28, 2024 Share Posted July 28, 2024 Nice sleuthing! I just checked, they have 4,979 in stock :) Quote Link to comment Share on other sites More sharing options...
batflash Posted August 4, 2024 Author Share Posted August 4, 2024 Hey all, Following up here. I went ahead and ordered another bunch of encoders from Digikey to complete a swap of all 6 screen encoders. Man, not only do they work perfectly, but they feel good too. A little stiffer/tighter turn, which makes dialing into a value with precision just right. The buttons on the encoders work perfectly too. The press and hold on the older encoders were crapping out as well too. I'm glad these worked out. Anyway, these are Bourns encoders, so I'm hoping that these will last longer than 5 or 6 years that the original ones did. Another thing I'm noticing is the GUI is a bit snappier. I have a feeling that because the old encoders might've been failing, and it might have had an effect on how the GUI was responding. Tuner was slow to open, taking upwards of 15 seconds of holding. The effect block menu was slow to scroll and laggy. Still not as fast as the HX Stomp though. Lots of oddities in the past year or so, maybe longer. I'll report back if anything odd happens with this round of encoders. J 1 Quote Link to comment Share on other sites More sharing options...
