Hotkeys / MIDI notes sticking?
ryanh92
I'm not sure the best way to explain this so I'll do my best. I'm using the Helix Floor to control Logic Pro X. Mostly using Hotkeys but sometimes I send MIDI notes from it as well. Most of the time, it works perfectly. However, every now and then, the message I'm sending from the Helix to Logic will stick, as if it were set to "latching" instead of "momentary". So, for example, if I sent a message to Logic to start playback, it glitches out and starts playing the first .01 seconds of the song continuously until I go in change the message it's sending (which is the only way I've figured out how to stop it after it starts). Has anyone else encountered this problem or maybe have any advice on how to prevent this altogether? I'm primarily using this in a live setting which makes this situation very nerve-wracking. Thanks so much!
