uddude Posted March 12, 2023 Share Posted March 12, 2023 Hi am relatively new to Helix ( I have the HX Stomp XL) I am trying to get it setup and running well to replace a big board for fly dates. One problem I am having is that most ( not all of the time) when I change presets between songs when practicing ( I have not yet gigged with it) Is that it produces a loud thump/ chunk/ popping sound when changing presets - similar (but not quite as bad as) to pulling a cable in and out of a guitar with out muting first. What do I need to do to ensure that this "changing preset noise" does not get to the amp / mixer on a gig. Thanks Quote Link to comment Share on other sites More sharing options...
georgie_n Posted March 15, 2023 Share Posted March 15, 2023 I ran into this situation when switching presets on both HX Stomp & Stomp XL. After a day or testing presets, I learned it only happened with adjacent presets where the looper block was last in chain, after the Dual IR block. After I modified my presets to have my looper block before my IR block, the problem disappeared on both HX Stomp & Hx Stomp XL. Hope this helps Quote Link to comment Share on other sites More sharing options...
theElevators Posted March 15, 2023 Share Posted March 15, 2023 I've heard that on my Helix--if you have different amps between the 2 presets, and if you have any transpose blocks, or if you have a different impedance settings for the same amp, they do produce a noise. Quote Link to comment Share on other sites More sharing options...
georgie_n Posted March 15, 2023 Share Posted March 15, 2023 On 3/15/2023 at 1:04 PM, theElevators said: I've heard that on my Helix--if you have different amps between the 2 presets, and if you have any transpose blocks, or if you have a different impedance settings for the same amp, they do produce a noise. Yep, anything with a big change in gain stages, output levels or impedances can cause a pop when switching presets. That instant change with the differences is essentially acting like a DC spike aka switch pop. The Looper last in chain with 2 identical presets can cause this as well with HX Stomp & Hx Stomp XL. I think that may be a 3.5 bug as it only started since I upgraded to last firmware on both my Stomp and XL units. On separate board builds. Now I always ensure my Looper is not last block and/or before the IR block. Hopefully that is addressed in next firmware build Quote Link to comment Share on other sites More sharing options...
uddude Posted March 15, 2023 Author Share Posted March 15, 2023 Ok - good to know I have not yet gone through the process of leveling out the gain of different presets. I will do that AND move looper away from last block. Hopefully that makes this thing useable on stage. ( I am new here so I only ever used 3.5) Quote Link to comment Share on other sites More sharing options...
PierM Posted March 15, 2023 Share Posted March 15, 2023 On 3/13/2023 at 12:07 AM, uddude said: Hi am relatively new to Helix ( I have the HX Stomp XL) I am trying to get it setup and running well to replace a big board for fly dates. One problem I am having is that most ( not all of the time) when I change presets between songs when practicing ( I have not yet gigged with it) Is that it produces a loud thump/ chunk/ popping sound when changing presets - similar (but not quite as bad as) to pulling a cable in and out of a guitar with out muting first. What do I need to do to ensure that this "changing preset noise" does not get to the amp / mixer on a gig. Thanks Use Snapshots instead jumping presets. You wont have a seamless preset change, even if you do a volume leveling between all of them. The pop and noise is mostly due the DSP memory unload and reload happening every time you change presets. Quote Link to comment Share on other sites More sharing options...
uddude Posted March 19, 2023 Author Share Posted March 19, 2023 Sure of course I am using snapshots to change tones within a song, but between songs ( where I might be changing instruments) I certainly need to change presets without making the sound techs ( and audience) hate me. Should there be a way to do this. People are not using the same preset ( with different) snap shots for an entire gig? Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 19, 2023 Share Posted March 19, 2023 On 3/15/2023 at 1:19 PM, uddude said: …I have not yet gone through the process of leveling out the gain of different presets. I will do that AND move looper away from last block. …. On 3/19/2023 at 6:24 PM, uddude said: … Should there be a way to do this. People are not using the same preset ( with different) snap shots for an entire gig? Unfortunately you do need to spend a good deal of time balancing your preset levels. Set the device Master Volume high; this sends the cleanest signal to FOH and also allows the lower gain, clean presets to reach a good volume. Use the level controls that do not colour the tone; the ones I find most useful are amp Channel Volume and the Output block Level. Start with the clean presets. After getting those to a good level, and balanced among themselves, move on to the crunchy tones and finally the hi-gain tones. You’ll need to do a lot of back and forth comparing and adjusting among all the presets. I’ve heard some people say they manage a complete gig using only one or two presets with several snapshots in each. Those folks are far better tone builders than me and must be able to coax a wider variety of tones out of a single preset. I think it also depends on your band/gig. If you play in a tribute band, or a genre band (e.g. blues) you probably don’t need as many presets. But if you play in a wide ranging cover band and want to nail the sound you will need a lot of presets. And that’s where gain staging among presets becomes very important. 1 Quote Link to comment Share on other sites More sharing options...
