volcanotim Posted March 27, 2023 Share Posted March 27, 2023 Can I use a Bluetooth adapter like this dongle https://www.amazon.co.uk/TFUFR-Bluetooth-Transmitter-Receiver-Supports/dp/B09Q8X3LP6/ref=sr_1_14?keywords=bluetooth+receiver+usb+b&qid=1679925916&sr=8-14 with an adapter like this https://www.amazon.co.uk/SHANFEILU-Female-Print-Adapter-Converter/dp/B0BPCY7GV6/ref=sr_1_3?crid=135WX749CFACE&keywords=usb+to+usb+b+adapter&qid=1679926945&sprefix=usb+to++usb+b+%2Caps%2C75&sr=8-3 to turn it into USB B type so I can plug it into the USB of my Helix so that I can play backing tracks over Bluetooth from my iPhone? If not what the solution? Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted March 27, 2023 Share Posted March 27, 2023 No, won't work as the Helix is no USB host (which would be needed for that BT plug to work). The solution is using either a plain old audio cable (3.5mm to 6.3mm, TRS) and run it into the aux input or a camera connection kit running into the USB port. In that case, the Helix should become available as a playback device on your iPhone (no warranty, though, I'm not using an iPhone). 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted March 27, 2023 Share Posted March 27, 2023 On 3/27/2023 at 3:24 PM, volcanotim said: plug it into the USB of my Helix so that I can play backing tracks over Bluetooth from my iPhone? If not what the solution? Hi, If you want to have your iPhone/iPad communicate via USB for playing backing tracks etc., you need the Apple Camera Connection Kit. https://www.apple.com/uk/shop/product/MK0W2ZM/A/lightning-to-usb-3-camera-adapter I have used the ACCK for a long time to hook up to my iPad, I also have an IK Multimedia iRig2 and iRig Acoustic Stage to allow me to use GarageBand on the iPad to quickly grab ideas when not in the studio - but that is for sending audio in to the iPad. https://www.ikmultimedia.com/products/irig2/ https://www.ikmultimedia.com/products/irigacousticstage/ Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
volcanotim Posted March 27, 2023 Author Share Posted March 27, 2023 On 3/27/2023 at 3:56 PM, SaschaFranck said: No, won't work as the Helix is no USB host (which would be needed for that BT plug to work Thanks but That doesn’t make sense. I’m able to play audio through a USB cable to the Helix. All I want to do is replace the cable with a Bluetooth receiver. I’m inclined to just buy them and try it unless anyone can explain why it won’t work and what will? Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted March 27, 2023 Share Posted March 27, 2023 On 3/27/2023 at 11:44 PM, volcanotim said: Thanks but That doesn’t make sense. Let me tell you: It does. But let me also tell you: I had a tough time grasping the "concepts" behind things as well at first. On 3/27/2023 at 11:44 PM, volcanotim said: I’m able to play audio through a USB cable to the Helix. Sure. But in that case, the Helix serves as a USB client (or "slave", if you will). On 3/27/2023 at 11:44 PM, volcanotim said: All I want to do is replace the cable with a Bluetooth receiver. I know. But for that to work, you need a USB host (or "master", if you will). You'd need that for power supplement as well (which USB B ports don't deliver). On 3/27/2023 at 11:44 PM, volcanotim said: I’m inclined to just buy them and try it unless anyone can explain why it won’t work and what will? Feel free doing so. You got the explanation above, though. Your BT plug wouldn't even wake up as there's no bus power running on the Helix' USB port. Seriously, it's pointless to even just try. 1 Quote Link to comment Share on other sites More sharing options...
volcanotim Posted March 27, 2023 Author Share Posted March 27, 2023 Ok I get it now thanks. So apart from a cable solution I guess I could use something like this into the aux and edit each patch to play the aux input HVMLAK Aux Bluetooth Receiver for Car, Mini Bluetooth Aux Adapter v5.3 with Swivel 3.5mm Audio Jack for Hi-Fi Home Stereo Music Streaming, Handsfree Calling, 12 Hours Battery Life, Adjustable Volume https://amzn.eu/d/aTnBMdE Quote Link to comment Share on other sites More sharing options...
datacommando Posted March 28, 2023 Share Posted March 28, 2023 On 3/28/2023 at 12:15 AM, volcanotim said: Ok I get it now thanks. So apart from a cable solution I guess I could use something like this into the aux and edit each patch to play the aux input HVMLAK Aux Bluetooth Receiver for Car, Mini Bluetooth Aux Adapter v5.3 with Swivel 3.5mm Audio Jack for Hi-Fi Home Stereo Music Streaming, Handsfree Calling, 12 Hours Battery Life, Adjustable Volume https://amzn.eu/d/aTnBMdE Hi, again, You are misunderstanding about the Bluetooth connection in general - it’s just not up to the job, (if it was, people would be doing it), and it has been discussed at length in these threads over quite some time. One word - Latency! Here’s one: https://line6.com/support/topic/34109-helix-to-run-bluetooth-headphones/ plus: More: Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
PierM Posted March 28, 2023 Share Posted March 28, 2023 ...it wont work unless you are fine getting a backing track with a 250~300ms latency. Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted March 28, 2023 Share Posted March 28, 2023 No idea what latency has got to do with this. Doesn't really matter when it's all about a backingtrack. 1 Quote Link to comment Share on other sites More sharing options...
PierM Posted March 28, 2023 Share Posted March 28, 2023 On 3/28/2023 at 2:04 PM, SaschaFranck said: No idea what latency has got to do with this. Doesn't really matter when it's all about a backingtrack. Oh yeah, you are right. My head was thinking he was going to send to iphone via BT transmitter, while it's exactly the opposite, so latency isn't an issue. Quote Link to comment Share on other sites More sharing options...
Fred2515 Posted October 21, 2023 Share Posted October 21, 2023 On 3/27/2023 at 5:56 PM, SaschaFranck said: No, won't work as the Helix is no USB host (which would be needed for that BT plug to work). The solution is using either a plain old audio cable (3.5mm to 6.3mm, TRS) and run it into the aux input or a camera connection kit running into the USB port. In that case, the Helix should become available as a playback device on your iPhone (no warranty, though, I'm not using an iPhone). Thanks for the explanation. Quote Link to comment Share on other sites More sharing options...
jester700 Posted October 22, 2023 Share Posted October 22, 2023 On 3/27/2023 at 7:15 PM, volcanotim said: Ok I get it now thanks. So apart from a cable solution I guess I could use something like this into the aux and edit each patch to play the aux input HVMLAK Aux Bluetooth Receiver for Car, Mini Bluetooth Aux Adapter v5.3 with Swivel 3.5mm Audio Jack for Hi-Fi Home Stereo Music Streaming, Handsfree Calling, 12 Hours Battery Life, Adjustable Volume https://amzn.eu/d/aTnBMdE Yes; something like that would work. That thing, into the proper adapter cable, into aux in on the Helix. Quote Link to comment Share on other sites More sharing options...
Fred2515 Posted October 23, 2023 Share Posted October 23, 2023 On 10/22/2023 at 2:23 PM, jester700 said: Yes; something like that would work. That thing, into the proper adapter cable, into aux in on the Helix. Yes, thanks. Yes, I agree with you. This problem can often arise with similar technology, and I have encountered such difficulties. However, after I read the article about airdrop to macbook a lot became clear to me and I learned a lot of new information. Indeed, it is very important to find quality information to cope with such errors. And fortunately, I found answers to my questions. Quote Link to comment Share on other sites More sharing options...
xocin49767 Posted August 9, 2024 Share Posted August 9, 2024 On 3/28/2023 at 3:07 AM, datacommando said: Hi, again, You are misunderstanding about the Bluetooth connection in general - it’s just not up to the job, (if it was, people would be doing it), and it has been discussed at length in these threads over quite some time. One word - Latency! Here’s one: https://line6.com/support/topic/34109-helix-to-run-bluetooth-headphones/ plus: More: Cars can be a pretty complex topic. Sometimes capturing them on film is just as challenging as buying them. But with https://www.faxvin.com/license-plate-lookup/arizona, a service that lets you check a car's license plate before buying it in Arizona, you can make things a lot easier. It's practical and convenient since all the necessary information is gathered in one place. Hope this helps/makes sense. Thanks a lot! I had the same question 1 Quote Link to comment Share on other sites More sharing options...
