Does the Helix Effects (HXFX) output the dry signal though USD like the Stomp does?
neilx
On 4/22/2023 at 5:44 PM, silverhead said:
No. The HX FX a is not an audio interface device.
Ah. OK. So I need to get the dry signal before it enters the HX FX. I can do that with my old Boss DM-2W Delay pedal which has a direct out without the effect, giving me a splitter.
Not necessarily before it enters your HXFX. It has 2 inputs that you can use. Run one dry and one wet - dry to DAW, or place a Send block first in the signal chain to feed your audio interface into your DAW. Check the HX Effects owner’s manual.
https://line6.com/data/6/0a020a411710a6112a67116f0b/application/pdf/HX Effects 3.0 Owner's Manual - Rev C - English .pdf
Hope this helps/makes sense.
