PLEASE VOTE: Different frequency curves for hi/lo-cut in cab block
Elephantstomp
Hello,
to reduce harshness I use a hi-cut.
Because the cab block´s hi-cut curve is to wide it cuts off too much wanted frequency of my tone.
So I use a separate EQ block. Kind of a waste with limited blocks (HX Stomp).
Same for lo-cut.
A perfect situation would be to be able to choose from different curves for hi/lo-cut within the cab block:
-6dB, -12dB, -18dB, -24db/Oct.
But I would always go with the steepest curve (-24dB/Oct) for a most narrow cut.
Thanks & please vote UP :-)
https://line6.ideascale.com/c/idea/90122
On 6/15/2023 at 10:02 AM, Elephantstomp said:
Hello,
Same for lo-cut.
As mentioned by @Schmalle in the post above.
(Standard cut and paste guidance response)
Before posting any new ideas, please do a search to see if it's already been listed. Multiple requests for the same thing will thin out the votes.
Also, post your ideas one at a time. Many users don’t vote for combined suggestions.
Only then should you use the “Helix Ideascale Community Submissions” thread in this forum to let other users know what your suggestions are, with links to IdeaScale, so they can vote on it if they wish.
Hope this helps/makes sense.
Hello,
true, you´re right.
But the already existing idea
EQ Cut filters FULL frequency spectrum AND adjustable db/8va
Adjustable high and low pass slopes for cabs and ir's
doesn´t clearly mention to include it in the cab block.
That´s what I am hoping for.
Would be sad if it gets just implemented in EQ block (sad for HX Stomp users).
What should I do?
On 6/15/2023 at 8:42 AM, Elephantstomp said:
Hello,
true, you´re right.
What should I do?
Add it as a comment to the original idea.
