HX sounds harsh
mattonium
Hey all, thanks for having me here. I'm new to the HX, just got it yesterday.
I've been playing around with it going into a '66 Bassman head with an orange cabinet.
A couple of observations and maybe someone can tell me if I'm doing something wrong or my expectations are out of line.
1) Most of the distortion units sound quite harsh. Not much low-end or warmth. Some of them are unusable to my ears.
2) Just plugging my guitar in to the input and output to amp input seems to degrade the signal and thin it out, while bypassed too.
3) It also seems like when you use any effect, the overall sound becomes somewhat brittle and harsh.
Lemme know if any of you experienced folks have any comments. I'm all ears!
It would help to know a few things before answering:
- What Helix device are you using?
- Does your amp head have an FX Loop?
- How, exactly, are your devices connected? Provide cabling/routing details.
- If your Helix device has amp/cab modeling, are your presets designed so that you avoid using two preamps or two cabs at a time (both modeled and physical simultaneously)?
If you are running your HX device with a distortion into an amp that can easily get overdriven (like the Bassman), then if your signal is too hot, it will sound harsh.  Try lowering the output level (in global settings, set it to instrument, or mic), or simply turn down the volume knob of HX Effects so it stops being harsh.  I think you are overdriving the amp with the very hot signal, that's what's happening.
Some amps are very clean, no matter how hot the signal, others have that warm sound, especially if you really crank it.  Even an effects loop can add a certain harshness to your sound on some amps (for me, all Marshalls do that).
No FX loop and I'm just plugging my guitar straight into the HX Left input and the left output straight to the amp. Amp has channels jumped so the 2 input feeds the bass channel. I usually have my bassman set in the 3-5 range and use a Weber Mass 100 attenuator. I will probably be using my analog overdrives and fuzzes but would obviously be interested in getting just this unit to sound as good as possible.
When you jumper channels the amp's input impedance is lowered, too. Try 230kOhm input impedance so that your guitar's electrics "see" the about the same load as if you'd plug into the amp directly. That will reduce "harshness" a little.
With no FX Loop on your amp you can’t use the 4CM so you are always going to be feeding the HX device output into your physical preamp section. You still haven’t told us which Helix device you have. It matters if it has amp/cab modeling because then you need to manage feeding one (modeled) amp output into a second (physical) amp. That generally won’t sound good.
