gtavares Posted July 14, 2023 Share Posted July 14, 2023 i want to use just headphones to practice at night. please tell me how to mute the mains on my stomp xl? i have to turn off my studio monitors everytime, there must be an easier way? Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 15, 2023 Share Posted July 15, 2023 ….. moved topic to Helix forum for greater visibility….. Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 15, 2023 Share Posted July 15, 2023 I don’t think the signal at the headphones output can be separated from the main outputs, meaning individual control can’t be done with any Stomp settings. You may find it easier to remove the cables from the Stomp Outputs on the rear panel. Otherwise you will need to use an external on/off switch device between the Output cables and the speaker cables so that you can place it conveniently. As an aside, you say the difficulty is that you have to turn your studio monitors off every time you want to use headphones. Does that imply that your monitors are always on, even when you are not using them? If not, then you are turning your monitors on/off every time you want to use them anyway. What’s the issue about simply not turning them on (or disconnecting them from a power bar?) when you use headphones? Quote Link to comment Share on other sites More sharing options...
Schmalle Posted July 16, 2023 Share Posted July 16, 2023 You can connect your monitors with an additional multiple socket with on/off switch. You can pull out the plugs of the signal cables to your monitors about 6mm (1/4"). You can add a stereo Send block last in the chain and set Global Settings-> Ins/outs -> Phones Monitor to Send. 1 Quote Link to comment Share on other sites More sharing options...
theElevators Posted July 18, 2023 Share Posted July 18, 2023 I have 2 power strips: one turns on the Helix, wireless, bass amp. Another one turns on mixing monitors and my studio sign. So if I want to mute my sound, I can simply turn off the 2nd power strip. 1 Quote Link to comment Share on other sites More sharing options...
