Used cable out of AMP out. Set global setting to pre cab/IR - I adjust mic on cab, and it changes sound, why?
daveaphotopod
On 11/22/2023 at 2:36 PM, daveaphotopod said:
Ok, so what did I do wrong? The only reason I adjusted the mic on the cab was to prove to myself that the pre cab/IR was working. Apparently, it wasn't, and I am glad I checked.
Having said that, I don't believe anything is wrong with the POD GO at all. So.....what did I forget to do?
How are you monitoring the sound? In other words, are you sure you are hearing ONLY the sound from the Amp Out jack?
