daveaphotopod Posted November 22, 2023 Share Posted November 22, 2023 Ok, so what did I do wrong? The only reason I adjusted the mic on the cab was to prove to myself that the pre cab/IR was working. Apparently, it wasn't, and I am glad I checked. Having said that, I don't believe anything is wrong with the POD GO at all. So.....what did I forget to do? Quote Link to comment Share on other sites More sharing options...
rarellano Posted November 24, 2023 Share Posted November 24, 2023 Plug it on main out L Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 25, 2023 Share Posted November 25, 2023 On 11/22/2023 at 2:36 PM, daveaphotopod said: Ok, so what did I do wrong? The only reason I adjusted the mic on the cab was to prove to myself that the pre cab/IR was working. Apparently, it wasn't, and I am glad I checked. Having said that, I don't believe anything is wrong with the POD GO at all. So.....what did I forget to do? How are you monitoring the sound? In other words, are you sure you are hearing ONLY the sound from the Amp Out jack? Quote Link to comment Share on other sites More sharing options...
cain29671 Posted November 25, 2023 Share Posted November 25, 2023 Make sure the cab is at the end of the chain. Quote Link to comment Share on other sites More sharing options...
daveaphotopod Posted November 26, 2023 Author Share Posted November 26, 2023 On 11/24/2023 at 5:51 PM, rarellano said: Plug it on main out L The pre cab/IR works with the amp out Quote Link to comment Share on other sites More sharing options...
