Thienpont Posted January 13, 2024 Share Posted January 13, 2024 I noticed that, after the 3.71 update, the 'PAGE Right' button on HX Stomp is no longer responding. 'PAGE Left' still works as normal. Pressing both 'Page Left + Right' also does not work anymore (probably because Page Right does not work). I have done a factory reset as suggested in the update procedure. Any suggestions? Quote Link to comment Share on other sites More sharing options...
lou-kash Posted January 14, 2024 Share Posted January 14, 2024 Works fine for me, so it must be something specific with your device. Quote Link to comment Share on other sites More sharing options...
Thienpont Posted January 14, 2024 Author Share Posted January 14, 2024 Thanks for checking. I did another reset and now it all works again as normal. It could be something with my device, occasionally the stomp starts and hangs, no sound, no response from the buttons. Power cycle tends to fix it but it is annoying. Luckily it does not happen too often. Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 14, 2024 Share Posted January 14, 2024 On 1/14/2024 at 12:04 PM, Thienpont said: Thanks for checking. I did another reset and now it all works again as normal. It could be something with my device, occasionally the stomp starts and hangs, no sound, no response from the buttons. Power cycle tends to fix it but it is annoying. Luckily it does not happen too often. If you reach the point when you want to investigate that behaviour I would start by testing the power supply that came with the device. Quote Link to comment Share on other sites More sharing options...
Thienpont Posted January 14, 2024 Author Share Posted January 14, 2024 Power supply? How could the power supply trigger the stomp hanging non responsive? I was thinking of buying a second power supply as the one that comes with the device does not look so solid built. Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 14, 2024 Share Posted January 14, 2024 I'm no electrician but it seems to me that if the power supply is failing it could be delivering an inconsistent voltage which causes interruptions in the performance of the Helix device. Quote Link to comment Share on other sites More sharing options...
lou-kash Posted January 15, 2024 Share Posted January 15, 2024 On 1/14/2024 at 6:04 PM, Thienpont said: occasionally the stomp starts and hangs, no sound, no response from the buttons. Power cycle tends to fix it but it is annoying. Oh, that symptom, on the other hand, has definitely increased for me as well, but already with the 3.70 update, and literally starting the same day when I updated the device last November. Quote Link to comment Share on other sites More sharing options...
richardglee24 Posted February 2, 2024 Share Posted February 2, 2024 Try reset but Page right button still doesn't work for me. Quote Link to comment Share on other sites More sharing options...
JakeHodges Posted October 30, 2024 Share Posted October 30, 2024 My page right button also doesn't work now. Power cycling has no effect. I'm running 3.71.0 I found a YouTube video that shows how to reboot into a test mode, and that seems buggy too. PGLT (and other buttons I mash) will register, but PGRT does not. Then it hangs after a few seconds. It seems like a physical button issue in my case. Anyone have any luck with fixing this? Quote Link to comment Share on other sites More sharing options...
