chunduus Posted February 6, 2024 Share Posted February 6, 2024 I have an external midi pedal, Harley Benton MP-500. The menu and configurations are pretty limited and I'm almost certain that the default firmware can only send values 0 & 64. This works fine fore effects but with any of the splits the first value chooses L or A but the second value of 64 only sets the balance to almost center (R1 or B1). How can I get the 64 value to et the balance to R100 or B100? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 7, 2024 Share Posted February 7, 2024 If all you need is A100/B100 just use an A/B Split. Otherwise you're screwed. The MP-500 is about as minimal as a MIDI controller can get. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted February 7, 2024 Share Posted February 7, 2024 On 2/6/2024 at 5:46 PM, chunduus said: How can I get the 64 value to set the balance to R100 or B100? By using Bypass Assign instead of Controller Assign. Use the CC message to bypass the Split block and toggle between default value (bypassed) and your setting (activated). 1 Quote Link to comment Share on other sites More sharing options...
