ovidionasone Posted February 14, 2024 Share Posted February 14, 2024 Hi, I tried importing a tone into HX Edit and got the attached error message. Never had this message before, I have an HX Stomp and the tone I tried importing is an HX Stomp tone. Suggestions appreciated thx Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 14, 2024 Share Posted February 14, 2024 Where did you get it from? Maybe if you link to the tone, or attach it? Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 14, 2024 Share Posted February 14, 2024 Seems like it’s not an HX stomp tone. It seems to requires more DSP than the Stomp is capable of. Do you know the origins of this preset? Quote Link to comment Share on other sites More sharing options...
datacommando Posted February 14, 2024 Share Posted February 14, 2024 On 2/14/2024 at 3:37 AM, ovidionasone said: Hi, I tried importing a tone into HX Edit and got the attached error message. Never had this message before, I have an HX Stomp and the tone I tried importing is an HX Stomp tone. Suggestions appreciated thx Hi, It seems to me that the wording in the error message may indicate that you are trying to import a setlist rather than an individual preset. Check the file extension - Presets = .hlx Set Lists = .hls Bundles = .hlb Backup = .hxb I don’t think that the code -8701 is one that I have seen before, but because it mentions, “Preset translation not supported, DSP block constraint exceeded”, I would guess that is an error generated by a preset that came from Helix Native, which uses Hardware Compatibility and stops presets from loading into hardware that has insufficient DSP. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
