Import my M9 settings to an HX Stomp XL? And even my Atomic Firebox (at least the IRs)?
aksman
Is there a way to import to an HX Stomp XL my M9 settings? And even my Atomic Firebox (at least the IRs)?
I have relied on my M9 for countless tours and shows, and always had a backup board all set... Atomic Firebox direct to PA, Line 6 M9, a v1.1 OCD, and a couple others. I LOVE the sounds I get from that setup, but I needed to size down to fit as carry-on for fly-dates.  NOW, I'm trying to make this happen. Is there ANY WAY to get the settings for some of the effects on my presets off of my M9 and into the HX Edit?  AND, how about the Atomic (at least the IRs I bought for it, as transferring the amp models doesn't seem to be a logical option.
If anyone can please help, it would be greatly appreciated!!!!
Thank you for the reply!  Now, to figure out how to get my mono set "stereo delay" to give me what i want. I really just want a 4 head delay BUT with 8 heads to choose from instead. Any chance it exists in this thing? Or can be suggested???
Well, there might be a couple of stereo delay options to try out - the Multitap 4 and Multitap 6 with up to 4 seconds delay time available on each. The Cosmos (space) Echo allows you to access various combinations of the 3 tape heads across 2 seconds can get a little crazy. Run some of these in series, or parallel, and make yourself really dizzy. Oh, yeah, there is a Multi-Head delay in the Legacy section that is possibly the 4 head version from the old M9 units.
Hope this helps/makes sense.
On 3/29/2024 at 11:39 AM, datacommando said:
Thank you! I'll check out these delays asap!
