Is there a way to manually control the automated filters?
lisanovak
I'm new to using the Helix and am attempting to mimic my physical pedal setup within it. While I understand replicating complex pedals like the Digitech Dirty Robot may be unrealistic, I thought replicating the Moog MF Drive would be more feasible, focusing on its lopass filter aspect controlled via an expression pedal. However, I've struggled to find a straightforward lopass filter in the Helix that allows expression pedal control over the cutoff frequency. The "filters" section seems to only offer automated options, and a wah pedal, despite being somewhat similar, doesn't produce the same depth or sound as a lopass filter. Is there a way to manually control the automated filters, or another method to achieve the classic filter effect found in synthesizers?
As a noob to the Helix world, and wanting to dig beneath the surface of the usual stuff, you might find that purchasing a copy of this would be a good investment. Full of good stuff.
Hope this helps/makes sense.
