Are there any shorter versions of the Variax Cable?
On 5/22/2024 at 8:54 PM, deagonx said:
I keep most of the variax cable wrapped even when I'm using it, because 25' is just so much longer than I have any use for. I was wondering if any shorter cables are available.
https://btpa.com/EtherCon-Ethernet/EtherCon/Line-6-Variax/
I got one of these years ago, 10' if memory serves. High quality cable, reasonably priced.
On 5/24/2024 at 4:06 PM, FuselloIon said:
Hi, do I need a special tool for that?
Since the Ethernet cable without ends must first be inserted into a part of the Ethercon Canon casings (the part that then simply has to be screwed on) it is necessary to have an RJ45 crimping tool to build the complete (cable + RJ45 connectors) Ethernet cable from scratch and only then attach the final part of the Canon casings.
If you want to avoid DIY, you can find, for example, on Amazon ready-made Ethercon cables available in various lengths at affordable prices that work well.
Here in Italy I found this:
DG Systems - Cavo Ethercon schermato per AES50, Dante, ArtNet, Madi, ACE - Made in Italy (5 mt)
Thank you for the detailed explanation! I think I'll go with the ready-made cables to keep it simple
