Helix Floor volume dropping then going load
Orb8
Hi all, as the title says, my helix floor (which is out of warranty now) but still looks brand new. Has developed a
Volume issue.
It starts working fine, but within about 10mins the volume will either drop really low or come up rather loud,and it will keep doing this every few minutes, but mostly the volume stays low and then comes up loud out of the blue.  I've tried changed amps & cabs just incase and it's still the same.
Any ideas please?
P.S.... Does anyone have a schematic for the Helix Floor please
For troubleshooting, eliminate anything that can adjust volume...
  • If you have a volume pedal block (often assigned to the EXP... disable it)
  • As stated above, disable the big volume knob from your outputs
  • I would also disable the Global EQ if you are using it...
Make sure you try the 1/4", XLR and headphone out to see if the problem is everywhere, or just on one set of outputs.
