Helix PRESET button problems (btn 2 on diagram)
johnnyvlee
I have two Helix floor units. I bought the second one as a backup so that if one went on the fritz I could still do a show.
Both of them have a problem with the PRESET button which is button 2 on the diagram in the manual.  You push it to get setlist, but on both of my units they no longer function.  This could potentially be a real problem for me on stage.
Is this a common problem? And if so, is there an upgraded replacement component for it?
I have to drive to another city to get repairs, and I obviously can only have one in repair at a time if I have upcoming shows. So, I'm a little concerned.
  • 2 months later...
You must really push that knob/button in a lot, or your case is damaging it.  Maybe the gig bag, or the case is applying constant pressure to the encoder/knob when the Helix is inside.
I almost never press those buttons: save, presets, amp, etc, or the joystick.  They are extremely flimsy.  Before I go to my gig, I leave my Helix in the correct set list.  I also order my presets at home (unless the singer decides to change the order at the last second).  I do all of that on the computer, using HX Edit.  Same applies to building my presets--HX Edit is the way to go.
