PlayinOcean Posted November 26, 2024 Share Posted November 26, 2024 So i finally decided that 3 switches is not enough for my Stomp. I saw multiple suggestions for the Ampero FS 1 as a cheap way to add the switches 4 and 5, so I bought it. Plugged it in, assigned an effect to FS 4, but nothing happens. I did tell the Stomp in Global settings to regard switches 4 and 5 as FS 4/5, so I really don't see what the problem is here. Maybe a faulty unit, or am I missing something? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted November 26, 2024 Share Posted November 26, 2024 In HX Edit, open the SETTINGS (gear icon at lower left)>Device Settings. IDK for sure how they need to be configured for that device, I use an ME SP1-L6 Exp Pedal instead of a switch. Hope you bought it somewhere with a good returns policy. AFAICT from trying to get help with the POS Ampero Control I bought last week, their support people have never responded to anybody. Headed back to Amazon... Quote Link to comment Share on other sites More sharing options...
jpdennis Posted November 26, 2024 Share Posted November 26, 2024 On 11/25/2024 at 4:02 PM, PlayinOcean said: So i finally decided that 3 switches is not enough for my Stomp. I saw multiple suggestions for the Ampero FS 1 as a cheap way to add the switches 4 and 5, so I bought it. Plugged it in, assigned an effect to FS 4, but nothing happens. I did tell the Stomp in Global settings to regard switches 4 and 5 as FS 4/5, so I really don't see what the problem is here. Maybe a faulty unit, or am I missing something? Is the Ampero FS 1 using momentary switches? If so you may have to use momentary as the type of engagement of the switch when assigning the blocks. I do not have a stomp so maybe someone who does and is smarter than I can explain better if a momentary device can be set to latching on the Stomp. 1 Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted November 26, 2024 Share Posted November 26, 2024 On 11/26/2024 at 5:57 AM, jpdennis said: Is the Ampero FS 1 using momentary switches? If so you may have to use momentary as the type of engagement of the switch when assigning the blocks. I do not have a stomp so maybe someone who does and is smarter than I can explain better if a momentary device can be set to latching on the Stomp. Exactly this. And yes, it can be done. I'd rather use at least one of he switches for tap/tune, though, simply because I prefer to have visual control over things, something the Ampero switch doesn't offer. 1 Quote Link to comment Share on other sites More sharing options...
lou-kash Posted November 26, 2024 Share Posted November 26, 2024 In Global Settings > Preferences make sure to set EXP/FS Tip to FS4 and EXP/FS Ring to FS5. If it's set to EXP1/2, the switches won't work because the Stomp logically expects an expression pedal. Other than that, the Ampero Switch is a rock solid device that just works. 1 2 Quote Link to comment Share on other sites More sharing options...
PlayinOcean Posted December 5, 2024 Author Share Posted December 5, 2024 On 11/26/2024 at 9:58 AM, lou-kash said: In Global Settings > Preferences make sure to set EXP/FS Tip to FS4 and EXP/FS Ring to FS5. If it's set to EXP1/2, the switches won't work because the Stomp logically expects an expression pedal. Other than that, the Ampero Switch is a rock solid device that just works. That was the missing link, thanks a lot! Quote Link to comment Share on other sites More sharing options...
