Findlasse Posted January 29 Share Posted January 29 Hi! Has anyone experienced that the button and background lights suddenly have stopped working?. Apart from that it works fine and did since 2019!. Hoped it was the flat cable gone out of the socket, but it was glued and looked good. As you may be able to spot: Teemah is selected and Cave is not. Hard to see when gigging Tried updating and back dating, factory resets without succes. Repair will be as expensive as buying a new one, but it just seems odd as it works fine - just no lights. Any suggestions? Quote Link to comment Share on other sites More sharing options...
datacommando Posted January 29 Share Posted January 29 On 1/29/2025 at 5:47 PM, Findlasse said: Any suggestions? Hi, I know this may sound obvious, but have you checked the Globals to see if the LED brightness is set to “Off”. Something that I have never felt the need to use, although it seems the option is there. There is also this in the manual To customize the footswitch’s LED color, turn Knob 5 (Switch LED) to select the desired color (or turn it off). Normally, you should leave this set to “Auto Color. Hope this helps makes sense Quote Link to comment Share on other sites More sharing options...
theElevators Posted January 29 Share Posted January 29 How does it behave on a new blank preset in snapshot view? For your "new preset" preset, the buttons should all glow in red when you activate a snapshot. You can also test the LEDs are working: 1 Quote Link to comment Share on other sites More sharing options...
