Philipozz Posted January 31, 2025 Share Posted January 31, 2025 I use an Ampero controller to switch presets on both my amp and HX One via MIDI with a series of messages. My problem is that the ability to use the flux (both via the onboard switch and MIDI) disables when I press a button that calls the same preset that is already loaded. This also locks the preset from having parameters edited through the knobs. If I want to use flux or edit the preset, I have to pick another and then go back again. I tried finding an explanation in the manual and I doubt this behavior is intentional from L6. There are some less pretty ways that I can get around this, like making multiple presets of the same effect or to make a dummy preset that is called between calling the same preset again, but these all ruin the flux by changing the settings instantly. My wishes/suggestions: That the HX One will ignore the PC command if the currently loaded preset is called again and nothing is changed. If something has changed: Reload the preset. The ability to actively change the flux setting to high or low instead of just toggling. Another question: How long does it take to load a preset? I tried making a series of commands to my amp and the HX One where the preset will be loaded and flux being toggled immediately afterwards. I didn't get it to work when doing it as a series of commands, but I could select the preset and then toggle flux. 1 Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 31, 2025 Share Posted January 31, 2025 Are you running the latest firmware? I know it fixed a bug involving Flux but I don’t know if it will fix your issue. Worth a try if you’re out up to date. Quote Link to comment Share on other sites More sharing options...
kwells1204 Posted February 2, 2025 Share Posted February 2, 2025 I have this same issue. Knobs are locked after loading the same preset twice. And if I try changing Presets via MIDI PC immediately followed by a CC4 message to toggle an effect OFF, the CC message is never processed. MIDIOX confirms my MIDI controller is sending both messages. If I command both messages, and the preset doesn't need to change, the CC4 message gets through. 1 Quote Link to comment Share on other sites More sharing options...
kwells1204 Posted February 3, 2025 Share Posted February 3, 2025 I am using the latest firmware 3.81.00. Quote Link to comment Share on other sites More sharing options...
opositif Posted February 15, 2025 Share Posted February 15, 2025 Same problem for me. I'm changing presets of my nano cortex and hx one with my graviton M2 midi controler with the hx one effect OFF by default. when I put effect on with the hx one the Flux works, but when I put effect on with the midi controler Flux is not working anymore... My midi comands for exemple : on Nano Cortex : PC10 and on Hx One : PC10 and CC1 with 0 value to put effect on and off And I'm with the last firmware 3.81 1 Quote Link to comment Share on other sites More sharing options...
kwells1204 Posted March 22, 2025 Share Posted March 22, 2025 When will we expect a fix to this? Also, I can't seem to enter a support ticket anymore on the website. I can't get past the first step. I click on the "Search" button and nothing happens. 1 Quote Link to comment Share on other sites More sharing options...
Almir_Matoso Posted March 26, 2025 Share Posted March 26, 2025 Em 31/01/2025 às 17h19, silverhead disse: Você está executando o firmware mais recente? Eu sei que corrigiu um bug envolvendo o Flux, mas não sei se resolverá seu problema. Vale a pena tentar se você estiver atualizado. Bom dia! Boa tarde! Boa noite! Gostei muito das atualizações para o HX Stomp, mas agora acho que deveria haver uma atualização para captura, já que o Ampero Stomp 2 teve essa atualização. Nós, consumidores da Linha 6, estamos esperando por isso. Vamos esperar com antecedência. Quote Link to comment Share on other sites More sharing options...
Pointlessaccount Posted April 1, 2025 Share Posted April 1, 2025 I have the same bug, I'm on the latest firmware 3.81.00 I opened a support ticket but no progress so far. Quote Link to comment Share on other sites More sharing options...
Pointlessaccount Posted April 9, 2025 Share Posted April 9, 2025 I am replying again here in the hope that this reply will be approved, my previous reply made 10 days ago is still hidden and showing "Your content will need to be approved by a moderator" I have the same bug, I'm on the latest firmware 3.81.00 I've opened a ticket with Line6 and the response is that "The senior guy here confirmed that this bug was fixed with 3.81." Which doesn't seem right, the claimed fix is never mentioned in any firmware bugfix list and everyone in this thread still has the issue on 3.81 Quote Link to comment Share on other sites More sharing options...
syntapunk Posted April 10, 2025 Share Posted April 10, 2025 I also have same issue of locking knob when i send the PC message twice. Quote Link to comment Share on other sites More sharing options...
kwells1204 Posted April 11, 2025 Share Posted April 11, 2025 I also sent in a support ticket. The response from Line6 was: "It's a known issue and logged as bug, I don't have time frame when it will be fixed but it's on the radar." Quote Link to comment Share on other sites More sharing options...
Pointlessaccount Posted April 14, 2025 Share Posted April 14, 2025 On 4/12/2025 at 5:24 AM, kwells1204 said: I also sent in a support ticket. The response from Line6 was: "It's a known issue and logged as bug, I don't have time frame when it will be fixed but it's on the radar." Could you please let me know your ticket number? The customer service rep. in my current ticket is saying the bug was fixed, it would be great to be able to point to your ticket where it has been accepted by line 6 as a known issue. I fell like the more tickets this bug is linked to the sooner it'll be fixed. It's the most egregious midi bug I've come across in my years of midi use, I'm pretty disappointed line 6 has been so slow to fix this. Quote Link to comment Share on other sites More sharing options...
rossedwards Posted April 19, 2025 Share Posted April 19, 2025 Just adding +1 to the list. I use a GigRig G3 to manage my MIDI switching and, since updating to 3.81.00 I'm seeing the same problem. My 'clean' patch on each G3 bank sends a PC message to HX One to select the relevant effect e.g. Chrome Custom wah. Works perfectly the first time I select the clean patch, but when I move to another preset (e.g. drive) and back again, the second (and subsequent) issuing of the same PC command causes the flux/exp feature to lock up - the only workaround is to select another patch on HX One before re-triggering the original PC message. Quote Link to comment Share on other sites More sharing options...
huzzam Posted April 24, 2025 Share Posted April 24, 2025 I'm having the same problem, with perhaps a twist... In my case, it seems like it's related to whether the HX One was on (not bypassed) when the PC message was sent. If the old preset was bypassed, the preset you change to doesn't work. If it wasn't bypassed, then the new preset will work ok. I've ended up adding an Engage (leave bypass) message right before the PC, and that works, though i get a momentary glitch before the preset changes, as the old effect breifly switches on. As for sending a PC and then a Bypass message, I've found that if I add a short delay (50ms seems to work well) after the PC, then send the Bypass, all works well. If your midi controller has a "delay" command, try that. (I'm on a Morningstar controller) The HX One is running firmware 3.81 Quote Link to comment Share on other sites More sharing options...
emsaudiopro Posted April 26, 2025 Share Posted April 26, 2025 This certainly seems to be the biggest issue for Line 6 to resolve on this product. I love the way this thing sounds...but if you're hard into MIDI - which you should be if you have this pedal - it's tough to work with. Feel everyone's pain on this. I have two HX1's and rely on a Boss ES-8 for MIDI control of them and a few strymons. I even replaced one of my strymons because I thought the HX1 would improve my workflow and reduce how much menu diving I do. But these MIDI isses are essentially making the workflow not any better. Quote Link to comment Share on other sites More sharing options...
bbeyer01 Posted October 24, 2025 Share Posted October 24, 2025 I'm having the same issue with my hx one, running the latest 3.81 firmware. I recall saved presets with my gigrig G3. The flux feature will freeze up, and I have to switch to a different preset before it will regain function. I know it's related to midi operation. When the preset is already loaded on the HX one, and the gigrig pulls the hx one into the signal chain (which sends another PC message to recall the preset), the flux feature will freeze. This is really my first time using midi, so I may not be explaining this very well. So my apologies! Very happy with the sounds and versatility on the hx one, would love to try and get this figured out... Quote Link to comment Share on other sites More sharing options...
bbeyer01 Posted October 27, 2025 Share Posted October 27, 2025 So, I think I may have found a somewhat backwards solution to the freezing issue. With the gigrig G3 (which may apply to other switchers capable of sending midi commands on the off push), I added another midi PC command to change preset on the off push. So when I pull the HX1 into my signal chain via a stompbox preset on the G3, it recalls the programmed preset I desire. When I press that G3 again to remove the HX1 preset from my signal chain, it sends another PC command to switch the HX1 to a different preset. This keeps the HX1 on a different preset until I choose to pull it back into my signal chain with the G3. The freezing issue would occur when the HX1 was already on the preset, and the G3 would pull it into the signal chain (and send a PC message to recall the already loaded preset on the HX1). It's kind of messy solution, but it may get you by until a proper firmware update can fix it the right way. There are a few things to be aware of. This won't work on any HX1 presets that you want trails from, as the preset is changing within the HX1. I also had to make sure the "secondary" preset that is recalled on the off push is set to be transparent from your core tone (ie no volume differences or tone changes/etc). You also have to use the Global setting on your flux feature. I just figured this out late last night, so I haven't gigged with it yet, but it should work better than having the HX1 freeze up. Hope that helps someone out there! Quote Link to comment Share on other sites More sharing options...
jiml6 Posted October 30, 2025 Share Posted October 30, 2025 This issue is fixed in the latest build, 3.83. Quote Link to comment Share on other sites More sharing options...
