netabuse Posted February 12, 2025 Share Posted February 12, 2025 So I bought a Line6 EX-1 from Amazon a while back, and the entire time I've had it, it's been almost useless. After using it for a while, it would invariably drift down from 0-100% to only go to like 0-65%. I adjusted it several times and made sure it was tightened and tried adjusting the start of the sweep, but no matter what, if I plugged it in and swept it from full up to full down, after anywhere from 20 minutes to an hour, it would drift back to 80% or less, despite being full-toe down. Part of the problem is that the full sweep of the pedal doesn't map to the full sweep of the pot, just under 0.75%, so it's like if I do the sweep when I connect it, eventually the Helix realizes the value isn't the full range. The weird thing is it still does this no matter which end I make the "overage" at with the adjustable grub-screw, the toe-down or the heel-down. I took the entire assembly out and put it in a stomp box with a big knob, so when I plug it in, I can get the full sweep of the pot to calibrate it. It hasn't exhibited the issue since then. Looking at the components, it's one micro 20k pot, a plastic jack housing, and a small circuit board labeled 'beep.com' (or beepcon), all as one soldered unit in a big plastic housing with an unmarked metal baseplate (with rubber feet). Is this a fake pedal? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 12, 2025 Share Posted February 12, 2025 When you contacted L6 Support, what did they say about it? 1 Quote Link to comment Share on other sites More sharing options...
Schmalle Posted February 12, 2025 Share Posted February 12, 2025 It's not a good pedal and it's incompatible with current Helix / HX stuff. You'll need a pedal with a 10 kOhm linear pot. Edit: The pot inside the EX-1 should be a linear 10 kOhm pot. If there is a 20 kOhm pot inside yours that's weird and the cause of the problem. Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 12, 2025 Share Posted February 12, 2025 I use two EX-1 pedals with my Helix Control (and Rack). No problems. I’m not a heavy exp pedal user but they’re not incompatible. Quote Link to comment Share on other sites More sharing options...
