HX Edit - can no longer drag and drop presets to change order
prskier17
I frequently reorder my presets to match setlist order.  Until recently this was a simple task in HX Edit.  Today it no longer works.  Rather that let me reorder, HX Edit asks if I want to overwrite the preset that I'm attempting to drag a different one above or below.  I'm using a Helix Floor and can still reorder on the Helix's physical screen.  Both the Helix Floor and HX Edit are up-to-date.  Anyone else have this issue and did you find a solution?
Thanks!
Chris
I don't have this issue.  Did it start all of a sudden?  Make sure your HX Edit matches the firmware version of the Helix, it's not behind or ahead.
As a workaround, you can use another set list and copy/paste presets there, or just use the Helix.
Same comments as the others - It works for me and look for the blue line.
Also, you could try reinstalling HX Edit v.3.82 to see if that fixes the problem.
Hope this helps/makes sense.
This just started happening to me yesterday.  I connected my older laptop and everything behaves as it should.  I uninstalled and reinstalled HX Edit 3.82 (Helix Floor is at 3.80) and the issue is still present on my newer laptop.  So this is an issue only occurring on my fairly new (~3 month old) Lenovo Legion 5 slim Windows 11 laptop.  Reordering worked fine on this newer laptop until yesterday.  I don't think I changed anything, but I guess it's possible I did...
Hmm.. new computer running Windows 11?
Could this be something related to the memory integrity and the driver?
I’m a Mac user, so I maybe misremembering something that first cropped up a couple of years back, where Windows 11 users found that switching off Core Isolation Memory Integrity feature fixed some issues.
