Two questions about the HX Stomp
357mag
I've heard you get 8 blocks. I've heard you get 7 blocks. I've heard you get 6 blocks. I don't know what you get. So what do you get? And that means that each block can hold an effect, like one distortion, one delay, one chorus, one flanger, one amp, one cab etc. Is that how it works? That would be 6 blocks already taken up. Does the unit really come with enough blocks to make a good guitar signal?
In the POD X3 series that was capable of sending a wet and dry signal into your recording software. Can the HX Stomp do that?
On 7/27/2025 at 3:02 PM, 357mag said:
I did not see anything in the manual about recording wet and dry at the same time. I am not very learned at recording.
See the USB Audio section, specifically DI Recording.
