Line 6 Mission EP1-L6 expression pedal not recognized
mkopec
Made the switch from the Helix Floor to the Stadium XL.  Been trying everything I can think of to get the Helix Stadium XL to recognize my pedal.  I use it for almost every patch and song.  Much appreciative of any feedback or advice.
Did you go into global settings -> switch/pedals -> Control (A or C) to match the type of EXP pedal your using?  Instead of TRS you might want Tip.  Forgive me if you've already done this and it is still not working.
  • 7 months later...
On 11/25/2025 at 3:08 PM, mkopec said:
Turns out they are defined as "Control Port" under the Controller Assign menu, of which you can add 4 switch or pedal devices!  What jmillion said, thanks!!
Okay, not sure if I'm following and don't have my rig in front of me. So you're saying that instead of choosing Exp Pedal I choose...what? Where? I'm actually down the street from Mission Engineering and was considering just grabbing the Stadium, my two pedals, and heading over, but that's kind of the nuclear option.
Here's where I'm at:
Global Settings > Switches/Pedals > page 3: EXP In (Control A-Tip). Am I in the wrong spot here?
