HX Effects Output
d_sic3
I tried searching the forums but couldn’t find clear information regarding the HX Effects outputs.
I’m planning to set it up with a Boss BCB-1000 and use the BCB send/return as my L/R outputs. Since the BCB uses TS jacks, I just wanted to confirm whether I need to replace them to properly match the HX Effects.
Questions below:
  1. Are the outputs balanced or unbalanced?
  2. Are the outputs TS or TRS?
  3. Are the send/returns (FX loop) TS or TRS?
Thanks in advance for the help.
Try here - page 8
https://line6.com/data/6/0a00051afdbe673ccc8bdcf2d/application/pdf/HX Effects 3.80 Owner's Manual - English .pdf
Hope this helps/makes sense.
