Personal_Shopper Posted June 12 Share Posted June 12 Hello everyone, I am having a serious issue with my Variax Shuriken SR250 and need your advice. While trying to do a factory reset and update the firmware, my guitar's battery suddenly died right in the middle of the process. The update was interrupted, and now the guitar seems completely dead. Here is what is happening now: When I connect the guitar to my Mac/PC using the original VDI-USB interface box, the software (Line 6 Central, Line 6 Monkey, or Workbench HD) doesn't see the guitar at all. The device list is just empty. The light on the USB interface box flashes red as soon as I plug the cable into the guitar. I tried the standard recovery trick (holding down the model selector knob while plugging it in), but nothing happens. The guitar doesn't respond to anything. Since the battery died during the factory reset, I am afraid the internal memory is completely wiped or corrupted. Is there any secret way or button combination to revive the guitar at home? Or is it completely bricked, and my only option now is to take it to an authorized service center? Thank you for any help! Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 12 Share Posted June 12 What happens when you insert the fresh fully charged battery? Quote Link to comment Share on other sites More sharing options...
Personal_Shopper Posted June 12 Author Share Posted June 12 On 6/12/2026 at 6:17 PM, silverhead said: What happens when you insert the fresh fully charged battery? When I insert a fresh fully charged battery, the LED indicators on the guitar light up and show a 100% full charge (4 green lights). However, the Model Selector knob LED does not light up at all when I press it or try to activate the guitar. The pickup on guitar works perfectly when I connect it through 1/4 Jack to the audio interface so I still can use it as a usual electric guitar. Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 12 Share Posted June 12 Look closely at the bottom of the Model Selector knob. In some cases it can touch the body of the guitar which prevents it from being fully depressed, meaning the electronics are not being turned on. If there is no interference from the body and the knob is being fully depressed, I would open a support ticket. Quote Link to comment Share on other sites More sharing options...
Personal_Shopper Posted June 12 Author Share Posted June 12 On 6/12/2026 at 11:33 PM, silverhead said: Look closely at the bottom of the Model Selector knob. In some cases it can touch the body of the guitar which prevents it from being fully depressed, meaning the electronics are not being turned on. If there is no interference from the body and the knob is being fully depressed, I would open a support ticket. Should the Model Selector knob make a distinct, physical "click" sound when pressed down? I have just removed the plastic cap/knob entirely to test it. However, even when pressing directly on the bare metal potentiometer shaft, there is absolutely no mechanical click or tactile feedback. Is the switch inside supposed to click, or is it a silent/non-clicking button? Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 13 Share Posted June 13 I’m not sure. Open a support ticket. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted June 15 Share Posted June 15 -Battery box sending a false low battery message to the main board. -Some glitch with the main board. -Problem with the VDI connector or jack plate circuit. -Problem with the encoder (rather rare occurrence). Those would be possible reasons. Like silverhead said, open a ticket. Also check with the authorized service centers near you,... https://line6.com/find/service_center/ Quote Link to comment Share on other sites More sharing options...
