Schivosa Posted 17 hours ago Share Posted 17 hours ago The snapshots are not changing in the Stadium Native presets. Anyone else having this issue? Quote Link to comment Share on other sites More sharing options...
silverhead Posted 17 hours ago Share Posted 17 hours ago Please describe exactly what you are doing when trying to change Snapshots, and compare that to the instructions in the manual. Let us know at what point the instructions are breaking down for you. 1 Quote Link to comment Share on other sites More sharing options...
Schivosa Posted 15 hours ago Author Share Posted 15 hours ago I select the snapshot drop down and when I select any snapshot from 2 to 7. It doesn't change to the selected snapshot. It stays on 1. Quote Link to comment Share on other sites More sharing options...
silverhead Posted 14 hours ago Share Posted 14 hours ago From the manual: In the Snapshot Panel, click one of the 8 snapshots to select a different snapshot. If you select a snapshot that hasn’t yet been configured, it appears the same as the snapshot you came from. As soon as you edit a new snapshot (say, by enabling or bypassing an amp or effect block), the snapshot becomes “active” and remembers any block’s bypass state and snapshot-assigned parameter values. Is this possibly the issue? Try copying and pasting a Snapshot. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted 14 hours ago Share Posted 14 hours ago What DAW are you using? I'm using Reaper, and the Snapshot won't change unless Stadium is ACTIVE/ENABLED (checked in the FX UI). Quote Link to comment Share on other sites More sharing options...
Schivosa Posted 13 hours ago Author Share Posted 13 hours ago I can't select a different snapshot. When I select any other snapshot, it still shows #1 selected. I am using Reaper. Where is the FX UI setting? I don't see it. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted 13 hours ago Share Posted 13 hours ago When you click the track FX button, the window that opens, containing the FX, is what I call the FX UI, because it is where the User Interacts with the FX. Each effect has a checkbox next to the effect name. Make sure that checkbox is checked. 1 Quote Link to comment Share on other sites More sharing options...
Schivosa Posted 9 hours ago Author Share Posted 9 hours ago On 8/19/2026 at 12:52 PM, rd2rk said: When you click the track FX button, the window that opens, containing the FX, is what I call the FX UI, because it is where the User Interacts with the FX. Each effect has a checkbox next to the effect name. Make sure that checkbox is checked. That's what it was! Thanks! Quote Link to comment Share on other sites More sharing options...
rd2rk Posted 7 hours ago Share Posted 7 hours ago De nada! Quote Link to comment Share on other sites More sharing options...
