NAM
fabrice0503
FEATURE REQUEST: NAM A2 Support for Helix LT
Dear Line 6 Team,
Please consider adding Neural Amp Modeler (NAM / NAM A2) support to the Helix family, especially the Helix LT.
The Helix already has powerful DSP, IR loading and a highly flexible signal chain. Adding a dedicated NAM block would give Helix users access to the rapidly growing NAM ecosystem of high-quality amp captures.
Even supporting only NAM A2-Lite or Helix-optimized models would be extremely valuable.
This could be a major firmware update that would extend the life and capabilities of existing Helix hardware without requiring users to buy additional equipment.
Please consider making NAM support a future Helix firmware feature.
I would definitely use this feature on my Helix LT.
Thank you, Line 6!
Best regards,
A Helix LT user
  • 2 months later...
On 11/13/2026 at 4:08 PM, hmoller said:
If you're not afraid to load custom firmware, on LT and stomp you can already have nam a2 lite
https://github.com/andreidevs/helix-lt-nam
Well, even if  it does appear that just about every other modelling unit can load and use NAM A2, right from the tiny Pocket Master on upwards, the official advice is not to do it.
This is from Frank R, over on BookFace.
https://m.facebook.com/groups/line6helixusergroup/permalink/3462267550623560/?
Of course they have to say just that.
My inofficial advice is to check it out in any case as the improvements are incredible. Gapless amp "channel" switching within one single block. Between up to 128 captured amps. That's just gorgeous. And quite obviously, some NAM captures sound fantastic (even if it's just the lite versions, there's very little differences between lite and full).
I've used the hacked software on my Stomp for more than a week now  and had no issues with it so far. It's great.
If I had the LT I'd try it.
The hacked firmware does not change the boot loader so you can always go back to the stock firmware. Even if the hacked firmware was totally corrupted and didn't boot up you can hold footswitches 6 + 12 while powering on (update mode) and upload the stock firmware.
So I guess the only drawback is that uploading an unofficial firmware to the device can be interpreted by Line 6 as a breach of warranty. So if your device doesn't start anymore during the warranty period and has the hacked firmware on it - that might be an issue.
I guess for Line 6 the main concern with this firmware hack is that could potentially add work for their customer service.
Also I think the Line 6 guys are basically hackers, so they probably have a soft spot for stuff like this. I mean what else are modded amps and pedals if not hacks - changes in the device to make it do what you want?
Just my two cents.
  • Upvote 2
Yeah - but also possibly that there's now quite some more pressure for them to improve the Stadium units. So far, there's pretty much just UI changes, Agoura amps and Showcase setting them apart from the OG units. If you don't care about Showcase and are fine with the old UI, I can see pretty little incentives to buy a new unit.
I would agree on that. I'm sure that pretty much any programmer is at least "fascinated" at what's happening right now (for good or bad).
My post was just a “heads up” about the official Line 6 take on the current/ongoing NAM issues.
Steve Sterlacci recently did a podcast with Steve Atkinson - the creator of NAM captures, and he (S.A.) says that he uses A2 Lite versions because, as you have already found, most people would not notice any difference in sound and they are more efficient on CPU power.
Personally, I have no objection to NAM as such, and I have even used the converted/resampled Snaptone versions of A2 captures in my cheapo, cheapo Valeton GP200. I find that the downside to this stuff is having to trawl through thousands of captures to find really good ones, in a similar way to how we all went down the “rabbit hole” of speaker IRs.
We are a constant state of flux with this stuff.
Well, first off: Parametric captures are already happening. And they will likely take off quite a bit in pretty much no time. Those would likely not run on the OG HX units, but there's already some tools allowing you to extract a static NAM capture from a parametric one, so you could just do the "homework" in a DAW and export the setting(s) you like the most.
Besides, you can tweak NAM captures a LOT. After all, many amp gain circuits and tonestacks are pretty simple things, not all that much different from what you get in various NAM player options. So once you find a suitable "middle of the road" capture, representing kind of the "essence" of whatever amp channel, some tweaking can take you a long way already.
I recorded the following example during a similar discussion on a forum, all of this is one single capture through one single IR with just some pre/post EQ and different gain settings applied (in the Tone 3000 plugin), plus a little reverb and delay here and there.
Six variations:
1) Original (just the capture and an IR loaded).
2) A kinda more oldfashoned "narrow mid" version.
3) Almost completely clean for some funky stuff and what not.
4) Even cleaner, some jazzy thing.
5) A kinda riffy rendition.
6) The noodling lead thing.
https://drive.google.com/file/d/1P7_LM3aR4m8XAR-aGaEvyU6BI3MBYbTv/view?usp=sharing
I think this is at least as efficient as any amp controls. Sure, you need to know your EQs a bit. And no, it doesn't sound like the authentic amp tone stack. But I couldn't care less.
  • Upvote 2
Thanks Sascha, some fine examples in those snippets.
I guess I should spend a little more time playing around with the Atkinson Gateway, Tone 3000, and Tonex Plugins I have installed in Logic.
It seems that the whole world of guitar gizmos are being modified and hacked around - even the humble old Zoom MS-70CDR hasn't escaped.
