ovidionasone Posted 2 hours ago Share Posted 2 hours ago Hi, never done this before so hoping to start on the right path :) I have a preset tone in Line6 HX Stomp I would like to use HX Edit app to add an harmonizer effect (perhaps choice of 3rd 5th or octave) and be able to activate it on and off with a pedal button Advice welcome thx Quote Link to comment Share on other sites More sharing options...
rd2rk Posted 2 hours ago Share Posted 2 hours ago If I understand what you're asking for, use snapshots. Assign the pitch/interval parameter to Snapshots. Set it the way you want it in Snapshots 1-3. In Command Center, assign a FS to Snapshots>Press/Hold. In SS1 set PRESS=SS2;HOLD=SS3. In SS2 set PRESS=SS1;HOLD=SS3. In SS3 set PRESS=SS1;HOLD=SS2. Be sure to SAVE the SS after each change and after your final SS SAVE go back to SS1 and SAVE again to set the default. The above is a suggestion. Set the PRESS/HOLD values to whatever works for you. Here's an example preset. It uses a different effect, but demonstrates the principle. FS 3way Toggle.hlx Quote Link to comment Share on other sites More sharing options...
datacommando Posted 1 hour ago Share Posted 1 hour ago On 11/30/2026 at 7:58 PM, ovidionasone said: Hi, never done this before so hoping to start on the right path :) I have a preset tone in Line6 HX Stomp I would like to use HX Edit app to add an harmonizer effect (perhaps choice of 3rd 5th or octave) and be able to activate it on and off with a pedal button Advice welcome thx Hi, To save me from lots of typing, it may be useful if you check out this video for a bit of insight on harmoniser FX. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
theElevators Posted 1 hour ago Share Posted 1 hour ago Quote Link to comment Share on other sites More sharing options...
