Rocchiuzzi Posted July 19, 2014 Share Posted July 19, 2014 Hello everybody, I've just played in a concert with a POD XT connected to a MKV Shortboard that I always use at home without any problem. I am not shure if the problem comes with hight volume or vivration on the stage, but the pod simply and sudenly restart itself while playing when it wants!!!!!! It doesn't care if I am on a silence or on the midle of a Solo. At first, I thought that It was an energy problem, but I start using a voltage stabilizer and the problem was not solved. Anyone had this problem??? Thank you !!! Quote Link to comment Share on other sites More sharing options...
BillBee Posted July 21, 2014 Share Posted July 21, 2014 Oooo that sucks. I would try a different power supply just in case the old one was starting to go, it takes more power to feed the FBV. Another thing could have been how hot it was. The problem hasn't repeated itself at home or practice? Quote Link to comment Share on other sites More sharing options...
Rocchiuzzi Posted July 21, 2014 Author Share Posted July 21, 2014 Hello BillBee !!! Thanks for your answer!!I haven't try another power supply (It will be the next tray ;) ).I think the temperature is normal and no, the problem usually happen on stage :SI'm going to try to find a log event into the file system from linux. If I get something relevant, you'll know it. Quote Link to comment Share on other sites More sharing options...
Vin_Dizon Posted July 23, 2014 Share Posted July 23, 2014 Have you tried backing up your patches and then resetting it to factory settings using Monkey? Quote Link to comment Share on other sites More sharing options...
