lefty6921 Posted September 2, 2014 Share Posted September 2, 2014 Wondering if anyone can help. I'm having trouble finding the best way to hook these 2 together. I tried the 4 cable method and I lose the duoverb sounds as well as the fx loop on/off. I went directly to the front but can switch pod off. I tried the effects loop, which seems to work but big volume difference can anyone help? Thanks Quote Link to comment Share on other sites More sharing options...
phil_m Posted September 2, 2014 Share Posted September 2, 2014 The 4-cable method should actually work pretty well with the Duoverb. If you had everything connected correctly, and had the FX Loop block in the right place in the HD500, you shouldn't lose the sounds from the Duoverb. The one thing is that the Duoverb loop can be stereo, so if you're using two different amp models on it, you'd have to connect the POD to it in stereo in order to get everything to work correctly. Quote Link to comment Share on other sites More sharing options...
lefty6921 Posted September 3, 2014 Author Share Posted September 3, 2014 thanks I will definitely try that. I like the idea of stereo. I also have a short board (which I forgot to mention) when I try to turn off the fx loop on the shortboard, there is no sound coming from the duoverb. I followed the youtube (line 6 support) on the 4 cable method, but no sound when I turn fx loop off. Any thoughts? Thanks for your help Quote Link to comment Share on other sites More sharing options...
sliding_billy Posted September 3, 2014 Share Posted September 3, 2014 I would just run it into the loop and use the DV as a power amp (dummy jack the guitar input on the DV to get sound). 1 Quote Link to comment Share on other sites More sharing options...
radatats Posted September 3, 2014 Share Posted September 3, 2014 definitely use the duoverb as a power amp. I had a flextone and while it was nice there is no comparison to the amps and tones in the 500... Just do everything in the POD and use the duoverb as power amp and speaker cab as sliding_billy said... 1 Quote Link to comment Share on other sites More sharing options...
lefty6921 Posted September 4, 2014 Author Share Posted September 4, 2014 Thanks for your help! I'll let you know how it works Quote Link to comment Share on other sites More sharing options...
lefty6921 Posted September 4, 2014 Author Share Posted September 4, 2014 Should I use trs if running stereo? Or regular rs Quote Link to comment Share on other sites More sharing options...
lefty6921 Posted September 4, 2014 Author Share Posted September 4, 2014 Should I use trs if running stereo? Or regular rs and, I hate to sound dumb but how do you dummy Jack the input? Thanks Quote Link to comment Share on other sites More sharing options...
radatats Posted September 4, 2014 Share Posted September 4, 2014 just take two regular TS cables from the left and right 1/4 outs on the POD to the left and right effects loop return on the back of the Duoverb. A dummy jack is just a guitar jack not connected to anything. You could use a spare guitar cable but it might pick up some hum. I would get a spare 1/4 inch jack and plug that in by itself, not wired to anything. PS - interested in how this sounds once you get it running... Quote Link to comment Share on other sites More sharing options...
sliding_billy Posted September 5, 2014 Share Posted September 5, 2014 Should I use trs if running stereo? Or regular rs and, I hate to sound dumb but how do you dummy Jack the input? Thanks For a dummy jack, I normally use an 1/8" to 1/4" headphone adapter that is laying around. Quote Link to comment Share on other sites More sharing options...
