joel_brown Posted November 10, 2014 Share Posted November 10, 2014 Been doing stereo for several years. It's a pain lugging around another amp/cab but when you set them on stage and spread them way apart it makes it all worth it. 1 Quote Link to comment Share on other sites More sharing options...
buscemrx Posted November 17, 2014 Share Posted November 17, 2014 After discovering the POD HD500 4 cable connection hookup to my Mesa Boogie Mark V amp, I finally found the perfect live situation. I dont like plugging the HD500 directly into the PA because I would need another monitor for to hear/feel the guitar. The 4 cable method sounds fantastic with the Combo Pwr input selected for the hookup. This method gives me total flexibility with my amp's peramp control as well. I recommend this from another's posting in line6 blog for showing the hookup. Once you understand the hookup and its control, patching tweeks are easy and sound great! The benefits of physically wiring your HD500 into your amp using the 4 cable method are: You can use the sounds of just your amp You can combine the pre-amp of your amp with the effects and power amp of your amp You can use the HD500 amp modelling and FX and completely ignore your amp's pre-amp With regard to the HD500 output settings, you would set the AMP/LINE switch to the left of the expression pedal to LINE and you would choose from: Combo Front Combo Pwr Amp Stack Front Stack Pwr Amp Dependent on the type of amp you have. Wire your guitar, the HD500 and amp together as follows: Guitar > HD500 Input > HD500 FX Send (using a mono cable) > Amp front input. Amp FX Send > HD500 L/Mono Return. HD500 Left Out > Amp FX Return To hear just the sounds of your amp: To just hear the sounds of your amp you would need a NULL preset to be set up in your HD500 - meaning no FX or Amp modelling. The POD will just route your amp's preamp signal through to the power amp stage. There may be some slight coloration doing this as you will be passing the signal through the HD500's circuitry. How? Set up a blank preset which has NO effects EXCEPT the FX Loop set to 100% output and 100% mix - you may need to adjust these levels to achieve similar levels to your amp with nothing plugged in. Make sure the FX Loop is turned ON on the HD500. Also ensure there are no amp models loaded. IF your amp's FX loop is switchable, you may be able to bypass the bulk of the HD500's circuitry by simply bypassing the HD500 in the amp's loop (but your guitar will still go via the input of the HD500 before it gets to the front input on the guitar amp) To use the HD500's FX with your amp's pre-amp and power amp: How? Set up an HD500 preset with NO amp or cab models loaded. For an example put a Wah at the start of the chain followed by any distortion FX you want say Screamer. Follow this with the FX Loop effect so it's placed BEFORE the mixer block. After the mixer block place modulation, delay and reverb for example. Make sure the FX Loop is ON and the Mix level is set to 100% To use the HD500's full modelling feature set and your amp's Power Amp only: How? Set up the HD500 as you would normally with Wah and Distortion type FX before the amp block/mixer block. Add in an amp model of your choice. Add in Modulation, Delay and Reverb or whatever after the Mixer block, But DON'T include the FX Loop effect anywhere in this signal chain. Note: The FX Loop isn't traditionally what I would term an 'effect' but for the purposes of this it behaves like an effect and falls within the FX group in the HD500, so that';s why I have referred to it as an 'effect'. Nick Message was edited by: nickmattocks 1 Quote Link to comment Share on other sites More sharing options...
stevekc Posted January 27, 2015 Share Posted January 27, 2015 Meanwhile if you happen to want accurate information on how to get the most from your Boss GP-10, and learn how a $35 Raspberry PI single board computer can add 5pin DIN MIDI I/O to GP-10,and locate user created GP-10 patches Boss GP-10 F.A.Q.http://www.vguitarforums.com/smf/index.php?topic=11796.msg85343#msg85343 http://roland.com/V-Guitar/about.html Quote Link to comment Share on other sites More sharing options...
mcolquitt Posted January 28, 2015 Share Posted January 28, 2015 All this conversation is a good thing. I see that this thread started last year and has been "bumping" in and out since then. Conversation and learning are all good things. What is NOT a good thing are forum suicides. I will NEVER understand - outside of the nose thumbing - are the ones that can not or will not simply pick up their guitar and go elsewhere without a long suicide note slamming gear that the vast majority of the people here really like. In the end I can't speak for everyone but if line6 isn't what you were hoping for then absolutely move on. At the same time don't expect us to care that you are going. Don't hate you for it nor do I have feelings about it in any way, I simply don't care that you don't like the gear we use or that you leave. Ciao So my hope for the OP is that he is happy with his new gear and when he goes to their forum one day to commit web-suicide there, the response will be somewhat different than the response he has recieved here. I am certain they will be just as polite about it. :P 3 Quote Link to comment Share on other sites More sharing options...
jazzpick Posted December 17, 2015 Share Posted December 17, 2015 bumping ..... :P I agree, suicide notes punching out gear, hurt the feelings of those whom sharing at most positive impressions of their favorite piece of gear, in the own forum brand field! that's like a war declaration :ph34r: but also there emerge an opportunity to review/check common sense, fairness and not least, manners and politeness. Reply quotes such as "everything coming from 'X brand' "is garbage" "crap" could be interpreted as an individual point of view, but also demonstrate ignorance and little forehead, plus an obvious bitterness, well away from a constructive position on the subject, especially and since is very difficult for an established brand like Roland or Boss messing around deceiving and folling millions of users, having among them thousands of outstanding producers, musicians and professionals in the area.Fortunately posters as Colonel Forbin and few more, place the stone of equity, fairness and valuable analysis, amid a outraged peat that simply reacts viscerally to a naive fool slap like Slooky hit.In my case, I am a proud user of LINE 6 gear from 16 years ago, including near of all POD series, POD HD for example has rewarded me with many hours of excellent performance. I've had my disappointments too, something that happens with all brands. Also I have Roland GR-55, GP-10, GT-100 etc just as I have had positive and negative experiences. But by the very mother of the universe I could never say the sound of the COSM amp / instruments / EFX is garbage junk. On the contrary, both LINE 6 and Roland / Boss, I have opened doors to the best of each. And both even, still it has much to learn from each other. Quote Link to comment Share on other sites More sharing options...
