pool80 Posted October 31, 2013 Share Posted October 31, 2013 One customer has replied that the following steps have helped with this problem. Please give the following a try and let me know if the performance has changed:- Press the Windows Key on you keyboard to access the Start Windows screen.- Right Click an empty space and select 'All Apps' from the bottom right hand corner.- Scroll over to the far right of the App screen and under Windows System, select 'Control Panel'- 'View By' in top right corner should be changed to large or small icons.- Select Power Options below- On the left side of the screen, select 'Create a Power Plan'- Select the 'High Performance' plan and hit 'Next'- On the next page just hit 'Create'- Next to your newly created Power Plan, click on Change Plan settings- Click on 'Change Advanced Power Settings'- In this new window, select your power plan, and go through the settings below it individually to manage your computer for best performance.- Under Hard Disk, set turn off hard disk after 'never.'- Under USB Settings, set USB selective suspend setting to 'Disabled.'- After making all these changes, click on 'Apply' and 'OK.'- Reboot the computer and test the performance of your USB audio and let us know if the problem persists. +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ This is a problem that seems to happen to some Windows 7 and 8 computers with many different types of audio interfaces. Here is a link from a Microsoft Support thread to review: http://answers.microsoft.com/en-us/windows/forum/windows_7-pictures/audio-stops-working-but-works-after-a-reboot/f3684f19-ee21-4e90-ae4c-98acb797d019?page=9&tm=1368283692511#LastReply There are many customers inquiring with the same problem with different audio devices from different manufacturers. One poster in the Microsoft support page (Zoolooz) provides a possible workaround to try: "Looks like problem solves by denying to use the playback devices in monopoly mode by software. Right click on speaker icon in tray - playback devices - speaker (do the same for headphones, previously plugged it in!) - properties (or settings, I'm not sure because of using cyrillic windows) - advanced - monopoly mode - unmark the first box. Hope this helps." I was unable to find playback mode, but go into Sound Playback Devices and right-click on your GX (which should have Speakers set to it) and and select Properties. In the Advanced tab of Properties, uncheck the box to allow the use of the device in Exclusive mode.I found also this procedure in another tech site with pictures of the steps to follow: http://dailykermit.wordpress.com/2009/09/11/windows-7-exclusive-device-control/ +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ Having had a similar experience recently with a custom built PC I built, it turned out to be a software conflict with:Intel® USB 3.0 eXtensible Host driversetEven on USB 2.0 ports different brands of audio interfaces would drop out in audio completely. Removing this driver and allowing Windows to automatically install Windows USB 2.0 drivers fixed the issue. This was on Windows 7, and Windows 8 does not use this controller, but I bring this up because with your computer being custom made, there is the potential for a conflict like this to happen. I also removed all of the Asus 'ASMedia' controllers and used intel based controllers instead. I would suggest you review your installed drivers and controllers to see if any of them have reports of creating conflicts like this. You might have to try updating the motherboard's BIOS if available as well. +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ f you are experiencing any kind of drop outs in audio, I would suggest that you increasing the buffer size used within your DAW as well as the buffer size slider in the Line 6 Audio MIDI devices menu located in the Windows Control Panel. ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ Hi there. It may be useful to someone advice from line6. I have not helped so far. I have a GX 8.1 for Windows 64 bit. ps. write to find a solution, suggestions ... Quote Link to comment Share on other sites More sharing options...
asurpnibal7 Posted January 5, 2014 Share Posted January 5, 2014 I had the same problem, but i think i've fixed it. I installed a previous driver version. I hope it works somebody! Quote Link to comment Share on other sites More sharing options...
nirv Posted January 8, 2014 Share Posted January 8, 2014 I have this problem in windows 7 even. I did a factory reset recently and the problem is still present. All my drivers are fine and up to date, any idea what else could be wrong? Quote Link to comment Share on other sites More sharing options...
pool80 Posted January 14, 2014 Share Posted January 14, 2014 She has just the latest update windows 8.1.64bit I test whether something has changed.In my previous drivers did not solve the problem. In windows 7 32 bit probably had problems, but solved them described above proposals. Quote Link to comment Share on other sites More sharing options...
kpedrosa Posted January 17, 2014 Share Posted January 17, 2014 help me out please windows 8 with line6 tone port ux2 is not working is working with xp but not with 8 :angry: help please :o Quote Link to comment Share on other sites More sharing options...
pool80 Posted January 19, 2014 Share Posted January 19, 2014 Unfortunately, W8.1 after the update, the problem still occurs. kpedrosa, the only thing I can advise is use written above fixes W8.1 not like the usb audio interfaces ... Quote Link to comment Share on other sites More sharing options...
FlavorFlav Posted May 24, 2014 Share Posted May 24, 2014 hi, i have exactly the same problem (with a Line 6 GX).... tried everything noted on this topic - without a successfull solution. is there any other low budget replacement? so i would sell my GX and by soemthing which works with windows 8 Quote Link to comment Share on other sites More sharing options...
bytewax Posted August 2, 2014 Share Posted August 2, 2014 HI I just found the fix after many hours of frustration. It's simple. Windows 8 and 8.1 users just go to: Device Manager -> sound, video and game controllers and disable whatever AMD or NVIDIA High Definition Audio Device this way: right click in the entry that says AMD or Nvidia and choose disable say yes and never your pod or whatever line6 device will never stop again... You can offer me a beer when you come to Portugal. :) Cheers Quote Link to comment Share on other sites More sharing options...
slammer88 Posted September 16, 2014 Share Posted September 16, 2014 Guys, please write to Support line, i'm doing it right now, and i'm really sick of this s.itpiece of device! Quote Link to comment Share on other sites More sharing options...
jorgedomenech Posted October 29, 2014 Share Posted October 29, 2014 Same here with Pod xt and Windows 8.1 and when I try to reboot the system it says "DRIVER_POWER_STATE_FAILURE". Every time the sounds freeze and the Winamp (or other software like youtube) stops to play and freeze, that error appears. 1 Quote Link to comment Share on other sites More sharing options...
BradyCav Posted December 1, 2014 Share Posted December 1, 2014 I have been having this problem for several years - and several versions of windows. What's interesting and frustrating is that only the Windows sounds stop. I use ASIO drivers in Sonar and even after the windows audio crashes, the sound in sonar continues to work. Incedentally, once the audio stops working the whole system seems to be come sort of hinky. Of course, neither Xbox music nor web audio works but iexplore.exe. tends to crash and the whole system tends to become sluggish and laggy. I've tried all the suggestions listed here including - changing settings so no audio device can take priority, disabling the usb power setting, etc. all to no avail. Can anyone provide any additional suggestions? This is so frustrating? Is there anyway to have Windows use ASIO instead of whatever it uses? 1 Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted December 1, 2014 Share Posted December 1, 2014 have you used slimdrivers? its a free utility that updates drivers.... it can sometimes find usb/chipset/motherboard drivers that fix things up... worth a try. Quote Link to comment Share on other sites More sharing options...
Whitie60 Posted December 2, 2014 Share Posted December 2, 2014 Anyone got a fix for these issues yet? I have some similar issues and have just opened a new thread. My issues are as follows. Operating System is Windows 8.1. I use Pod Farm 2 latest version with UX1 but also use the UX1 as a soundcard for other programmes. I use either Roni Amazing Slow Downer or Transcribe to rehearse and learn. I also may use Videolan VLC Media Player to watch and play against tuition videos. I use these and listen through headphones often so I need to be able to play them all into one source. Just to be clear I only use one of these other programmes at a time together with Pod Farm 2. I use the MME Drivers of the UX1 so there is no conflict with the Assio Drivers used by Pod Farm. This set up all worked fine in Vista but now with W 8.1 it works and then crashes all the time and will not work again until I re-boot the computer. All of the above progs work fine in W 8.1 when used as standalone but will only work for a short time with the Pod Farm and UX1. They are all compatible version for Wind 8.1. I have contacted Microsoft about the problems but they have referred me back to Line 6 stating that its a 3rd party Driver issue. Everything works well until I come to route the other progs through the UX1 when Pod Farm is in use. They all still work correctly with Vista so my UX1 is not the issue and still works correctly. I can supply the transcript of the support I received from Microsoft. This is the 2nd ticket i have taken out on this issue as the first one seems to have disappeared 1 Quote Link to comment Share on other sites More sharing options...
BradyCav Posted December 2, 2014 Share Posted December 2, 2014 Thanks, Zap. Just ran SlimDrivers. Fingers crossed. Quote Link to comment Share on other sites More sharing options...
Whitie60 Posted December 2, 2014 Share Posted December 2, 2014 It looks like there is no fix yet for these problems and that's probably why My Support Tickets have been ignored. When will Line 6 accept that there are major issues here and that the problem will not go away. We need some recognition that the problem has been recognised and is being worked on. It now appears that Pod Farm 2 is not compatible with Windows 8 operating system and needs an upgrade of some sort - any prospective buyers need to be made aware of this if they are operating from Windows 8 as a platform. It is likely they will experience major sound issues and other programs will crash. In some of the previous replies (above) i have seen some lame excuse from Line 6 stating that the UX1 and UX2 are not meant as a general sound-card . This is rubbish and a cop out that is totally unacceptable. People use various combination of gear and programs to practice and sometimes we need to put music from various sources into the sound-card especially for headphone use. As a Musician and technician to have solely Pod Farm at our disposal is limiting the potential that computers and software generally offers to us. Whats the use is having to go between 2 sources when you want to play along to existing music files or even when creating your own? For example say you lay down a backing and want to add a lead its no good when you cannot hear them together through the same source. Frankly the excuse from Line 6 was feeble and a cover up designed to take the heat of them. L6 need to take some responsibility for this issue and press on with a fix and stop giving feeble excuses for not doing so. Pod Farm was designed to facilitate using various other software at the same time for example you need to be able to play into a virtual mixing console (DAW). It's essential !. With Vista all this was possible so why has Line 6 now imposed limitations on the use of Pod Farm 2 by being seemingly incompatible with Windows new operating systems and any other Software programs they wish to diss in the process? 2 Quote Link to comment Share on other sites More sharing options...
FlavorFlav Posted December 21, 2014 Share Posted December 21, 2014 is there any line 6 device which works with Windwos 8.1 and PodFarm? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted December 21, 2014 Share Posted December 21, 2014 yeah pretty much all of them.... no software agrees with every computer... that's clearly the category that the previous poster falls in... but i've used the software on every operating system since xp including 8.1 with no issues. is there any line 6 device which works with Windwos 8.1 and PodFarm? Quote Link to comment Share on other sites More sharing options...
FlavorFlav Posted December 21, 2014 Share Posted December 21, 2014 yeah pretty much all of them.... no software agrees with every computer... that's clearly the category that the previous poster falls in... but i've used the software on every operating system since xp including 8.1 with no issues. i have 2 computers... with windows 7 everything works fine... with windwos 8 on both computers it stops working after ca 10-30 min... i tried everything fro mthe usb troubleshoot list. or another question: is there any other toneport/software like podfarm? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted December 21, 2014 Share Posted December 21, 2014 have you tried something like slimdrivers? a new version of windows likely has alot of default microsoft drivers... for things seemingly unrelated like your usb drivers, and chipset drivers... also try to avoid usb 3.0 if possible... its not as backward compatible as it should be. Quote Link to comment Share on other sites More sharing options...
jorgedomenech Posted December 25, 2014 Share Posted December 25, 2014 have you tried something like slimdrivers? a new version of windows likely has alot of default microsoft drivers... for things seemingly unrelated like your usb drivers, and chipset drivers... also try to avoid usb 3.0 if possible... its not as backward compatible as it should be. Tried with slimdrivers and everything is updated. The PodXT still have problems with Windows 8.1. Works for 20 min and then stops. We need a fix in a new driver asap cause we can't work with this kind of issues. Please fix it!!: Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted December 25, 2014 Share Posted December 25, 2014 the pod XT has been out for like 15 years now... i'm sorry to say... but windows 8.1 is completely unsupported... and there wont be any driver updates specifically to address that... Quote Link to comment Share on other sites More sharing options...
Serqent Posted March 27, 2015 Share Posted March 27, 2015 Just want to say, that I have the same issues like others described here, the whole package (audio dissapears, restart problems, driver_power_state_failure etc), my OS is W8.1, Pod HD. Everything started with Line 6 installation, no problems ever before, no problems with other USB interfaces (tried steinberg, tried zoom g3). Tried pretty much everything, nothing help. Submitted several tickets, got fast responses and different suggestions, unfortunately nothing helped so far. I am close to give up and use other interface. Quote Link to comment Share on other sites More sharing options...
ZombieRaptor2 Posted March 31, 2015 Share Posted March 31, 2015 Windows 7 user here, have been using my UX2 (and Podfarm) with Cubase for over a year. Then when I updated my Line 6 drivers through Line 6 Monkey everything started going wrong - I realised it was causing problems with playback on YouTube. In effort to revert back to how it was before, I used System Restore but was just left with no driver, and can't find any way to reinstall the older driver. The new driver, to put it simply, doesn't work. I can't get anything to play, and audio on Cubase doesn't come through. Essentially the UX2 is now useless until I can find a way to fix it. Quote Link to comment Share on other sites More sharing options...
dbmann1 Posted June 9, 2015 Share Posted June 9, 2015 Hi there, I have the same problem with a Thinkpad T400, Win 8.1 and the UX1. After some minutes of listening to YouTube videos the audio (and the video) stops. The only thing that brings back the audio is to restart the computer. Any suggestions? Quote Link to comment Share on other sites More sharing options...
Serqent Posted June 10, 2015 Share Posted June 10, 2015 Hi there, I have the same problem with a Thinkpad T400, Win 8.1 and the UX1. After some minutes of listening to YouTube videos the audio (and the video) stops. The only thing that brings back the audio is to restart the computer. Any suggestions? Yes, do not use UX1. I have tried pretty much everything, nothing helped unfortunately.... Quote Link to comment Share on other sites More sharing options...
pool80 Posted February 20, 2017 Share Posted February 20, 2017 IS the problem still exists to win 10 64bit? Someone managed to solve it? I wonder if the re-buy gx .. Quote Link to comment Share on other sites More sharing options...
jasontheguitarist Posted April 25, 2017 Share Posted April 25, 2017 IS the problem still exists to win 10 64bit? Someone managed to solve it? I wonder if the re-buy gx .. I have windows 10 64 bit with one of the old Toneport devices, latest driver still occasionally crashes and doesn't work until the machine is rebooted. The driver must still be goofy. Quote Link to comment Share on other sites More sharing options...
AusMakka Posted October 5, 2017 Share Posted October 5, 2017 I don't normally post to forums, but after experiencing issues with my UX2 with Windows 8 I found in the archived forums many other people were having the same problem (as recently as last month) with similar hardware. I was experiencing random audio dropouts on my PC. The audio would stop completely throughout all applications. The only way I could find to get it back was to restart my PC. I know it is not a hardware issue as I have a dual boot PC which runs both Windows 7 and windows 8. The UX2 always has always performed perfectly on Windows 7. Here is the solution which appears to have fixed the issue on my PC. I was experiencing the problem multiple times daily since installing windows 8, but haven't had it reoccur since I found this setting about a week ago. I've been pulling my hair out for months and was right on the edge of uninstalling Windows 8, but now it seems to be working great. I'm hoping this post can help others enjoy their line6 devices again. The solution: 1. open power options. 2. click "change plan settings" for the plan you are currently using 3. Click "change advanced power settings" 4. Under USB settings -->USB selective suspend setting --> setting, change to disabled (I have noticed the setting has changed itself back, but the problem hasn't reoccurred so maybe there's a bug in windows 8 in the power options. Maybe if yours is disabled by default, you could try enabling it) Sorry to make this post so long, but since the forums have been archived I couldn't reply directly in the thread where the problem was first mentioned. I hope this is a permanent solution and helps everyone. If it does maybe someone could shout me a copy of Podfarm2.5 Platinum...just kidding :P This has been driving me crazy on Windows 10. Just made the changes so let's see if this works. Thanks for the info! :) Quote Link to comment Share on other sites More sharing options...
pool80 Posted November 14, 2019 Share Posted November 14, 2019 IS the problem still exists to win 10 64bit? Someone managed to solve it? I wonder if the re-buy gx .. Quote Link to comment Share on other sites More sharing options...
cjmguitarist87 Posted March 19, 2021 Share Posted March 19, 2021 I tried all these things to fix it. Nothing. Finally i figured its probably a driver conflict. I went into device manager and disabled all other sound devices. Never stopped again. If i need the other devices i just re enabled them Quote Link to comment Share on other sites More sharing options...
