Sign in to follow this
shadymax84
Screen stuck at starting point....!!! Not working
I was using pod x3 live directly connected to an orange amp when all of a sudden due to poor power supply and incapable voltages the electric supply in my entire house got cut off and after a while it did come back but ever since then I've been having this problem where only the backlight of x3 live gets on meaning that it freezes at a blank yellow screen at the startup. I've tried changing the power supply (using different adapter) and resetting (which isn't possible because it doesn't show anything on the screen) and connecting it to the computer and flashing it(which is not possible because it doesn't show up in my computer) but none of these remedies have solved the problem. If someone has gone through this problem and found a solution then do let me know.
Make sure the other power supply is the exact same specs as the X3L.
Try this to reflash:
Q: How do I reflash in "safe mode"?
A: Safe mode can be used when a unit cannot be reflashed using the normal reflash procedure. Hold the four-way arrow key to the right while powering the POD X3 unit on to start your unit in safe mode. You can then reflash the unit as decribed above.
It may need to be serviced.
-B
Checking the Power Supply and a Safe mode reflash are the usual mortal fixes I've seen.
Someone else may pop by with a better method but until that happens I would suggest opening a support ticket:
http://line6.com/support/tickets/
Power surges can effect components in a really bad way.
-B
The light on the screen is bright with dark shadows. I fixed the RAM and the CPU Microcontrollers, is not tight by using hot air soldering back to normal again.
