russgoos 18 Posted January 19, 2015 Has anyone experienced this issue? I have a HD500X patch using one Bomber Uber preamp with no cab and a few effects. Sometimes, after playing for a few minutes, the sound from my DT amps get extremely muffled and extremely quiet only when using this specific patch. The following behavior seems odd: If I switch to a different patch that uses a different amp model, the rig sounds 100% normal. Then... when I switch back to the "problem" patch it also sounds 100% normal... for a while until the problem happens again IF the problem happens again. The problem sometimes appears, sometimes not, it's not consistent. My setup: Variax or regular guitar - HD500X - L6 link - DT25 combo #1 - L6 link - DT25 combo #2, both amps running in low volume mode. If I plug directly into either combo amp and disregard the HD500X entirely, the amps work A-OK and sound great. Just curious if anyone else has stumbled across this, perhaps on other amp (or preamp) models? I don't have my rig nearby right now, but the one thing I remember changing in the patch that might affect the DT25's was that I selected Topology IV instead of the Uber's default Topology III. I don't think that should matter, just thought that info might help. Thanks! Quote Share this post Link to post Share on other sites
MartinDorr 86 Posted January 19, 2015 You should be able to check for Hurghanico's idea of the problem source by first dialing in your tone with the HD and then changing the feedback type on the DT. If the problem is in the HD model changing the DT power amp config will not fix it. On the other hand, if changing the DT type will fix it, I'ld be suspicious of the power tubes next. They may fail in different severity for different feedback configurations. Martin Quote Share this post Link to post Share on other sites
russgoos 18 Posted January 20, 2015 Thanks hurghanico and MartinDorr, I'll try to experiment with the settings tomorrow. Quote Share this post Link to post Share on other sites
russgoos 18 Posted January 22, 2015 Another update. After a few more weeks of keeping the amps physical knobs at "not zero", the problem has not reoccurred. This when using the HD500X as the brain for my rig via Line 6 Link (using AES/EBU xlr cables). The problem never happens while plugging a guitar directly into the DT25's. ****************************************** Update to the update: The electric heaters were NOT the problem (info below). The issue happened again with the heaters unplugged. I *think* the issue is that I had the knobs on Amp 1 set to zero (except the master). My new theory is that the HD500X somehow was getting a knob control signal back from the amp and then dialing the mids to zero on the HD500X. Since the amp's knob settings are stored within the HD500X patches I don't think it should matter what the amp's actual physical knobs are set to, but perhaps it does actually matter. That said, I've set all the amp's knobs to 12 noon, reverb to zero, master set to given volume need. Haven't had the issue since. Fingers crossed. ****************************************** Update - the problem isn't just for this particular patch that features the Uber preamp. It happens on any other patch too. I figured out the problem. I can't explain why it happens, but I've discovered what is causing trouble. I noticed that the mid control would move to 0, all on it's own, at seemingly random times. On my Uber patch, the mid control has a drastic effect on the tone and volume. When the mid control would move to 0, the sound would get super muffled and quiet. On patches with other amps, the tone would just get "scooped" when the mids glided to 0... noticeable for sure, just not as drastic. At first I thought I must have a controller or oscillator assigned to the mid control that was causing this whacky behavior. Nope. It turns out that the 2 electric space heaters' power cords were causing some kind of electrical interference. My rig is set up in my unfinished basement. It's in Minnesota and it's a bit chilly in the basement in January so I added 2 small electric space heaters to the room. Those space heaters are powered on their own electric circuit that is separate from my guitar gear's circuit. However, the extension cord used to power the strip used to power the heaters runs directly over the top of my HD500X's power cord and L6 link cables. When I switched the heater's power strip off my whacky mid tone behavior stopped. Very very strange, but I'm glad the problem is fixed. I have no clue as to why it would just be a problem for the mid tone control. Weird, huh? Now I just have to figure out a better way to heat the room, haha. Quote Share this post Link to post Share on other sites
russgoos 18 Posted January 22, 2015 Thanks hurghanico :) Quote Share this post Link to post Share on other sites
innovine 56 Posted January 30, 2015 Knob jitter? Give it a squirt of deoxit. Check that the soldering is good, and redo it if unsure. Quote Share this post Link to post Share on other sites
noahgolden 0 Posted February 18, 2015 Yes! This happened to me, and I think it might have damaged a channel on my DT50. Quote Share this post Link to post Share on other sites
kkinerk_line6 1 Posted February 25, 2015 I have had similar issues when using the L6 Link. I was using a standard XLR cable. If the cable from the HD500 to the DT amp crosses any power cables, you can get interference. This can result in changes to the DT Amp configuration. I have since switched to an AES/EBU cable and carefully route it to ensure minimum interaction between this cable and power cables. Haven't had the problem since. This may not have been your problem, but it is something to be aware of. Quote Share this post Link to post Share on other sites
russgoos 18 Posted February 27, 2015 kkiner_line6, It's interesting that you've had problems with interference. All my xlr cables are AES/EBU. I haven't experienced the issue since bringing the amps physical knobs up from zero. Quote Share this post Link to post Share on other sites
