thomasmadsen1
Hi guys!
I just disconnected my POD 500X from my computer as the latency was unbearable. I think I'll try connecting my KRK 6's directly into it instead, but I noticed that the outputs on the POD are balanced whereas the inputs on the monitors are balanced for both XLR and TRS. Will this be a problem ? I've read somewhere that when monitoring from the balanced outputs on the POD, the volume gets really low unless you connect to an amp, but when using unbalanced directly it's quite allright for practising...?  Just wondering what kinda cables I should head out to buy on monday - cheers for any advice :)
-Thomas
Hi guys!
.....but I noticed that the outputs on the POD are balanced whereas the inputs on the monitors are balanced for both XLR and TRS. Will this be a problem ? .."
Not sure if you made a typo, but if both are balanced why would you anticipate a problem?
I suggest you use XLR cables.
